Question about Dryers
HOW TO REMOVE TIMER MOTER - Dryers
  • Controlfrk
    Controlfrk May 11, 2010
    Most timer motors are no longer available as a separate part. Model number would improve ability to be of assistance.
    President:
  • 1,922 Answers
Remove the screws holding the control panel on the top of dryer and replace the entire timer control unit
Posted on Sep 26, 2009
Dryer won't start
Is the door switch working properly?
Sep 14, 2007 | Maytag LSE7806A Top Load Stacked...
My dryer will not come on, however is getting electricity to the outlet, it just will not cut on
put the timer in time cycle,put your ear up to the timer and hear if you hear the timer moter working.if you do than you have a bad thermal switch.part#3392519.to replace this part you nead to remove the back panal and the power cord cover plate,look left and down and you will see a white plastic switch with two blue wires going to it.remove the two wires and remove the thermal switch.use a meter to see if the swith is open.if it is than replace it
Dec 28, 2009 | Roper REX4634KQ Electric Dryer
My Roper Dryer stopped working , what might I check to see what the problem is.
first make sure you have 220 going to the dryer.next put the timer on time cycle.next put your ear up to the timer and see if you hear the timer moter runing.if you do than you have a bad thermal switch.you will nead to remove the back panal and the power cord cover.on the lower left you will see a white plastic switch with two blue wires going to it.this is the thwermal switch,if you use a meter and this switch is open than you nead to replace it
Nov 12, 2009 | Roper REX4634KQ Electric Dryer
My washer is not spinning or draining properly, the timer is working, it will continue until it is in the off position but once it is my clothes are sopping wet. Is there a part I need or anyway I can fix...
if it is a top loader the moter controls the pump and spin u need to check power to the moter and clutch i.e if the moter runs but no spin the clutch has gone if its not geting the water out i can be the moter the best way to check is take the waste pipe out and put it in to a bucket and turn on the water should jet out if not the pump may be blocked try these first
Jul 29, 2009 | Kenmore 24032\24036 Top Load Washer
I need to replace brushes on a hotpoint aquarius wm32
pull machine out and make sure u remover the plug completley it is still live with the plug in and switched off throught the netural feed
at the back take off the botom white pannel made of plastic look in side pull the belt off the moter
there should be 2 10mm bolts remove these and tap the moter and it should slide out
remove the earth wire and the moter harness plug and pull the moter out it will go you might have to turn it this way and that once out there is two screws holding each brush remove and put in the new breushes replace the moter
to put the belt on there is two screws on the lid one each side behind a oval blanking cover these are hex head screws
once off put the belt on the moter pully first then on the drum pully and gide it on by hand turn the drum and the belt will spring on open the door and spin the drum by hand to make sure the belt is on correctley replace lid and back turn on power an try if this does not work the moter has gone try ebay i did for my hotpoint cheaper than trade on there
Jun 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Blower motor 94 dodge intrepid inop
1.disconect battery
2. remove lower right undre panel silencer duct
3. remove the blower moter connector from the resistor block
4. squeeze the blower moter wiring gromment and push the gromment throw the blower moter housing cover
5. remove blower moter housing
6.romove the screws holding the blower moter down
to put back on do the steps back werds
Jan 03, 2009 | 1994 Dodge Intrepid
Whirlpool Washing Machine does not spin in certain cycles
yes the timer can cause that but it could be the moter but more likely the timer
Nov 29, 2008 | Whirlpool Washing Machines
Dryers Logo
Top Dryers Experts
