Question about Remington Electric Chain Saw
Assembling chain to bar: r there 2 guides on either side of chain?
  • dontbother10
    dontbother10 May 11, 2010
    I'm old and a little infirm. 1. I don't understand what you are asking. 2. I can't read whatever it is you are posting. Please use a spell checker, if it can't understand it neither can I. Make, model number, and serial number of the helps some too. I can look it up and it helps me see what you are seeing and arrive at a solution to your problem. Think how you would explain this to Dad over the phone and type it out. Run spell check. Post clarification. Thanks.
  • 193 Answers
Remove plastic side cover - three screws on outer side,one screw on inner side.remove the two guide bar bolts.remove the phillips head screw going thru black bracket in middle of sproket gear. wear protective gloves and remove chain
Posted on Sep 25, 2009
How do you tighten the chain?
  1. Step 1: Loosen the Nuts on the Guide Bar Side Panel. This will give the guide bar and chain the room they need to be adjusted. ..Step 2: Adjust the Tensioning Screw. ...Step 3: Tighten the Guide Bar Side Panel Nuts.
Jul 06, 2015 | Garden
Chain wont tighten up
Jeff:
Loosen the two nuts on the right side cover of the saw (1/2 inch socket) turn them out 2 turns. Use a flat blade screwdriver on the screw at the right side front of the housing (near where the bar comes out of the saw). Turn the screw right until the chain can only be pulled up 1/8 of an inch at the top center of the bar. tighten the two 1/2 inch nuts. The two nuts clamp the bar so it won't move. If the chain tensioner still won't work, remove the right side housing by removing the two 1/2 inch nuts and look at the tensioner assembly and how it fits into the chain bar. The problem will be obvious. If you need to replace the tensioner assembly, a new one can be ordered through http://www.husqvarna.com.
Aug 16, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Friction ring assembly of remington model eleven
Examine the chain saw to verify that the chain is still attached to the sprocket. If any part of the chain is not on the sprocket the chainsaw will not cut correctly.
Check the tension of the chain. If the lower part of the chain drops away from the guide bar, you will need to increase the tension. Remove the shield on the side case and loosen the nuts on the guide bar with the wrench. Pull the guide bar to increase tension on the chain and then tighten the nuts.
Clean the chain if it appears dirty. A dirty chain will not cut as efficiently as a clean chain. Loosen the tension on the chain and then take the chain off of the guide bar. Soak the chain in a solvent, such as mineral spirits.
Examine the sprocket on the chain saw. If it appears worn, bent or out of pitch, a new sprocket will be needed.
Examine the chain to see if there are any damaged drive links. Replace the chain if too many of the drive links are damaged because the sprocket will not turn the chain.
Examine the guide bar to see if it appears crooked or is out of alignment. Remove the nuts from the guide bar by following Step 2. Take off the old guide bar and then install a new one.
Sharpen the chain if it looks shiny. The shine on the chain indicates that the steel that is underneath the chrome plating on the chain has worn away. Use a round metal file on the steel until there is a thin overhang of chrome over the cutting edge of the chain. This will restore the cutting edge
Read more: How to Troubleshoot a Chainsaw Chain ' eHow.com http://www.ehow.com/how_6317552_troubleshoot-chainsaw-chain.html#ixzz1fLUkDPOc
hope it helps
Dec 02, 2011 | Remington Garden
Assembly of McCulloch 335 chainsaw. do not understand B4. Check that small end of chain tension lever fits into bottom hole 18 of bar.
The chain adjuter is in the side cover ( chainbrake ) so you need to make sure the adjuster pawl in the brake ligns up with the hole in the guide bar, if not the chain will not tighten, and you will damage the cover if you tighten the bar nuts and the pawl is not in the bar hole.
Nov 01, 2011 | Garden
The blade on my McCulloch Electramac EM250-14 came off. How do I put it back on? Dan Enright
I am not familier with this machine, hoever the principle is the same for most machines, start by removeing the bar nut/nuts, remove the side cover, wind the chain adjuster screw fully back it may be in the saw or in the side cover, push the guide bar fully back, now loop the chain over the sprocket and lay it into the top of the guide bar, and around the tip, the cutting edge of the chain in the top of the guide bar should be facing away from the saw ( the chain rotates clockwise as you look at it ) replace the side cover, make sure the adjuster pawl is in the hole in the guide bar, assemble the nut/nuts finger tight, now adjust the bar so as the chain is touching all the way around the guide bar, with a gloved hand pull the chain around the bar manually to make sure it is properly on the sprocket, re tention the chain if required, lift the tip of the bar and fully tighten the bar nut/nuts, the chain should not sag on the bottom of the guide bar.
Feb 26, 2011 | Garden
How do I assemble the bar and chain on my 1.5hp chain saw MS1415?
Start by removing the bar nut/nuts, and remove the side cover, if the chainbrake is in the cover make sure this is off by pulling the hand guard fully back to the top handle, before removing the side cover, wind the chain adjuster screw fulley in toward the rear of the saw ( it may be in the crankcse, or in the side cover ) now assemble the guide bar onto the bar bolt/bolts, loop the cutter chain over the sprocket,and into around the tip of the guide bar, and into the bar rails, make sure the sharp end of the cutters on the top of the guide bar are facing away from the saw ( the chain rotates clockwise as you look at it ) now align the adjuster hole in the bar with the adjuster pawl on the machine, now re fit the side cover, if the adjuster pawl is in the cover make sure this lines up with the adjuster hole in the bar, assemble the bar nut/nuts finger tight, adjust the chain so as it touches all the way around the guide bar ( not sagging on the bottom of the bar ) with a gloved hand pull the chain around the bar to make sure it is free and sitting in the sprocket correctly, re adjust the chain if required, now lift the nose of the bar and fully tighten the bar nut/nuts
Feb 10, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
How do i put a chain back on a chainsaw?
Locate the bolts on the bar, down close to the engine. Loosen them. locate the chain tensioning adjustment, again, close to the engine, but on the other side. Loosen it also. Place your chain on the bar and on the sprocket. Tighten the bolts enough to take the slack out of the bar, but not so much that you cannot use the adjustment tensioning screw. Tighten up on the tension adjustment until the tension on the chain is right, and then tighten the bolts.
Best regards, --W/D--
Please feel free to rate this solution. Thanks
Jan 31, 2011 | Garden
What are the steps to replace a chain on a Husqvarna 345 chain saw?
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, now remove the two 8mm nuts securing the side cover, screw the chain adjuster in the crankcase fully back toward the sprocket, assemble the guide bar over the guide bar bolts and slide it fully back toward the sprocket, now loop the chain over the sprocket and lay it inthe guide bar raiuls and around the guide bar nose, make sure the sharo endge of the cutters on the top of the guide bar are facing away from the machine ( as you loog at it, it rotates clockwise ) now align the hole in the guide bar with the adjuster pawl, re assemble the chainbrake side cover back onto the saw, and fit the bar nuts finger tight, adjust the chain adjuster so as the chain is a snug fit all the way around the guide bar, with a gloved hand pull the chain around the bar manually, so as to make sure it is completly seated in the sprocket and bar rails, re tension if needed, hold the tip if the guide bar up and fully tighten the bar nuts.
Job done.
Jan 23, 2011 | Husqvarna Garden
How do I refit chain
Start by removing the side cover held with one or two nuts ( make sure the chainbrake if fitted is de activated by pulling the hand guard fully back toward the rear of the saw until there is an audible click ) if the chain has de railed you need to check for damage to the drive links, file away any burs, or fit a new chain, screw the chain adjuster fully back, assemble the guide bar onto the bar bolts and push fully back toward the rear of the saw, loop the chain over the sprocket and into the guide bar rails with the cutter teeth on top of the bar facing away from the saw if the bar adjuster pawl is in the crankcase make sure it fits into the hole in the guide bar, assemble the side cover, if the adjuster pawl is in the cover make sure this lines up with the hole in the guide bar ( adjust the pawl screw if required ), assemble the bars nuts finger tight, now adjust the pawl screw so as the chain sits snuggley around the guide bar, pull the chain around the bar with a gloved hand to make sure it is sitting into the bar and sprocket correctly, lift the nose of the guide bar and tighten the bar nuts.
Jan 22, 2011 | McCulloch Garden
Setting blade tension withouty gauge
With the chainsaw positioned and with the bar/chain combo loosely assembled properly on the chainsaw power-head. With the guide bar/chain adjuster inserted properly into the bar. Using a rag or wearing gloves. Notice how much up and down movement is at the guide bar tip. You must use this to your best advantage!! With the chain adjuster loose. finger tighten the bar nut or nuts. Hold the bar-chain assembly in the up position. To tension the chain, turn the adjuster in the correct direction to tighten the chain. DO NOT LOOSEN YOUR HOLD ON THE BAR, KEEP THE BAR IN THE UP POSITION. Rotate the chain along the bar to make sure it is free to move back and forth, KEEP THE BAR UP. Tighten the tensioner until the chain just touches the bottom of the guide bar. Check for back and forth movement again. Tighten the tensioner no more than a quarter of a turn. CONTINUE TO HOLD THE BAR UP. Now tighten the bar buts or nut snugly against the sprocket & chain guard cover. Check for movement again. If satisfactorily tight and free movement is attained the chain bar combination is properly adjusted.
This scenario will change with different types and brands of chainsaws. It is always very helpful if posters would include a modicum of make, model information with their queries.
Waltster
Oct 28, 2010 | Garden
Remington Electric Chain Saw  Logo
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
