Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker stopped working
I raised the temp in the freezer section just a little, and the icemaker stopped working. when i raised the temp again nothing happended. I turned off the refridg for a little while and then restarted. a while later a row of ice started to form, and then just stopped. any suggestions?
I have the same problem with my whirlpool every once in a while, and I found out that if I run a hot air dryer at the back of the fridge where the water tube comes in and along the ice maker it loosens everything up. I think that for some reason the water freezes in the tube somehow and prevents a full cycle. When I am using the hair dryer i can feel the frozen ice come sliding out of the tube. Also I know when I am getting close to thawing everything out when the ice maker runs through a cycle while I am blowing the hot air on it. Good luck.
Posted on Dec 16, 2007
  • fishdad Dec 16, 2007
    P.S. Let me know if this works for you because if not, maybe I should learn to keep my mouth shut. :-) I just know I have to do this about every three months.
I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to...
Check for freezer temp - if it is not 10 degrees or below the ice maker thermostat will not turn the ice maker cycle on by removing the frozen ice in tray and then refilling it for next dump cycle. And if freezer temp is high you may have leaking door gasket, dirty condenser coils, improperly operating self defroster which raises temps, low refrigerant.
Aug 04, 2017 | GE Refrigerators
Our icemaker just stopped working. I can feel ice
You need to replace the ice maker. If you could send a model we could get you the exact part number for that.
Thanks
May 23, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
My icemaker just stopped making ice today....please help
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My icemaker just stopped making ice - i can feel frozen ice in the top but it doesnt dump any ice out?
Take care
May 13, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I had the power out on my refrig for about 8 hours. Now the ice maker has stopped making ice. Water in the door works, but no water going to the ice maker and not dropping ice. Do I need to defrost the...
There is a dual acting water valve that feeds the ice maker and door water seperately.
If your power went out - chances are good the solenoid on the icemaker side of the valve has failed - so it will not open the valve on the demand of the icemaker timer.
To find out - you will need to check that there is voltage at the valve.
With a model #, I can help you better.
Thanks!!
Feb 20, 2010 | Refrigerators
Unit doesn't work when icemaker is on- Kitchen Aid Superba
that is unusual for the ice maker to cause it not to cool, but definitely not unheard of. if the fill tube to the ice maker, or ice maker itself, is leaking down the back of the freezer, behind the evaporator cover, it would form ice around the evaporator fan motor. this would cause the fan not to run, and the temp in the freezer and frige would rise. the ice would melt when it went into defrost, but then build up again. you should remove the rear panel in freezer and see if you see any ice build up around the fan blade, and if so, find where it is coming from. I hope this is the case for you. much cheaper than a compressor or new frige if it is. let me know if you have further questions. good luck, shane.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer Problem
The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
Oct 04, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
