Question about Texas Instruments Office Equipment & Supplies
My calculator's contrast is messed up. Current my Ti-83 plus's screen is blank. I tried to reset the brightness with 2nd up but won't work. Anyone have a good ideal?
  • Texas Instru... Master
  • 8,064 Answers
No offensee meant, but you may have used the procedure to darken contrast incorrectly
1. Press [2nd] key and release it
2. Press [ArrowUp] and release it
3. Repeat steps 1 and 2 in sequence until screen is dark enough.
If you want to lighten it: in step2 press [DownArrow].
Should this procedure fail, you may have to replace the main batteries.
Hope it helps.
Posted on Sep 25, 2009
My screen is blank to my Texas TI-83 plus calculator, batteries have been relaced
Increase the brightness of the calculator. To do this:
1) Press the On button
2) Press the 2nd button on the top left of the calculator
3) Press the Up arrow
4) Repeat steps 2 and 3 until the screen becomes brighter.
May 07, 2011 | Texas Instruments TI-83 Plus Calculator
I want to adjust the brightness and contrast on my TI-83 calculator
Turn the calculator on. Press and release the 2ND button. Press and hold the up-arrow key to increase contrast/darken the screen or the down-arrow key to decrease contrast/lighten the screen.
Apr 08, 2010 | Texas Instruments TI-83 Plus Calculator
My TI-83 plus calculator doesn't work
As battery gets drained, the screen contrast dims. But when you change batteries, some times the contrast is reset to some low value and the screen appears dead: it is so light that you do not see anything, and you think the calculator is malfunctioning. This is the most frequent reason users think the calculator refuses to turn ON. And I hope that is the case now.
To correct that, you must increase screen contrast: draken the screen a bit. To do so
  1. press [2nd] key and release it.
  2. Press the Up arrow and HOLD pressure.
  3. Keep pressing the arrow key until screen is dark enough.
If that solve your problem that is good, rate the post accordingly.. If that does not, do not get irate and berate the post. Post a comment here describing what you did and what message (if any) calculator returned, and I will give you further diagnostic steps.
Jan 20, 2010 | Texas Instruments TI-83 Plus Calculator
When i try to graph something on my TI-83 Plus, the screen fades to pitch black and then it says INVALID DIM
Reset the RAM to clear old settings that interfer with your new problem
[2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER].
Press [CLEAR] to clear the screen.
After a memory reset you may have to adjust screen contrast.
To increase contrast (darken the screen)
1. Press [2nd] key and release it.
2. Press [UpArrow] key and release it.
3. Repeat sequence until screen darkens enough.
To lighten the screen
2. Press [DownArrow] key and release it.
3. Repeat sequence until screen lightens enough.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 screen is black
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
Aug 29, 2009 | Texas Instruments TI-83 Plus Calculator
I accidentally pressed down for too long on my ti-84 plus calculator and i think it locked itself. how can i turn it back on? I NEED it for school!
From TI FAQs:
What troubleshooting can I try if the TI graphing calculator will not turn on?
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 24, 2009 | Texas Instruments TI-84 Plus Calculator
Ti 83 plus small black screen?
try pressing 2nd then hold in down arrow to change the contrast
Feb 14, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 countdown
Pressing 2nd then the up or down arrows is how you change the contrast on the TI-83. All you need to do is press the 2nd key then hold the down arrow to get your screen back. The countdown that you saw was just the value the calculator assigns to the contrast. It goes from 0-10.
Hope that helps!
Jan 18, 2009 | Texas Instruments TI-83 Plus Calculator
Help
You should press the 2nd and then hold the down arrow to cahnge the contrast. If that doesn't work then you should try resetting the calculator by taking both the back up and main batteries for 45 seconds.
Jan 16, 2008 | Texas Instruments TI-83 Plus Calculator
459 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
