Question about OKI MICROLINE 320 Turbo Matrix Printer
Prints on the same line more than once.
The printer sounds like a gear is stripped out. It prints on top of already printed lines. (Sometimes prints on the same line more than once.)
    Sergeant:
    Champion:
  • 208 Answers
Sounds like stripped gear alright. You can buy another Microline 320 on Ebay for $10 or $20 and strip the parts off it. If you can't find any, I can strip the gear you need off the one I have here. But this site has a policy of not allowing us to contact a customer directly though. I will have to check with the management and see how we can proceed.
Posted on Sep 24, 2009
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the seco
Is it prints or copies or both? If it's copies, clean the document feeder glass - small strip. What make/model? Laser? If laser, check the fuser roller
Nov 29, 2014 | Office Equipment & Supplies
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
About 15mm dark hadow vertical line on the page.
Sounds like its time for a new drum/print cartridge. When it get worn you start to get poor quality prints and sometimes lines. COule also be scratched and transfering the line on the prints but in either case needs to be replaced.
Jan 14, 2010 | HP Color LaserJet 2600n Printer
Carrier stall
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Press the "Menu" button 10 times. It should then read "Maintenance" on the printer's display screen.
2. Press the "Select" button once. You should then see "Cartridges" displayed on the printer screen.
3. Press the "Right Arrow" button 3 times, which then brings you to the "Self-Test" option.
4. Press the "Select" button once. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues and we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 03, 2009 | Lexmark X85 All-In-One InkJet Printer
Indicating a carrage problem, carrage going to fast and slaming into one on start up
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
try this printer self-test by following the steps given below:
1. Please press the "Options" button 10 times. "Cartridges" should now appear in the display screen.
2. Press the "Left Arrow" button once, which then brings you to the "Self-Test" option.
3. Press the "Select" button once. You will hear a series of clicks.
4. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about ½-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Oct 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
Text is not readable
It sounds like an alignment issue. If the first line prints correctly, there could be something stuck in the print-head path (like a piece of paper) or the "encoder strip or wheel" could be dirty.
Unfortunately the unit would have to be opened and inspected.
Lift the lid and look under the top cover to the extreme left and right to make sure there is no loose piece of crumpled paper stuck inside.
If this doesn't produce any results, try printing out the alignment page. Press Ink, then test print, then alignment. Print the page. There should be two sets of patterns. Zero represents a perfect pattern. Enter the number beside the pattern that looks closest to zero. You can see a line to each side of each pattern. Always choose the pattern where the line looks like one line, and not like two. If all you can see is patterns with two lines beside them always choose the lines that are closest together. The machine will move your selection to position 5. Print out the test again and select the best pattern again. Keep doing this until the checkerboard effect disappears, and the two lines on each side of pattern 5 have become one line. You may have to do this 10-15 times IF the alignment has gotten really bad.
If this doesn't help, or if it gets worse the unit will have to be opened and the encoder strip and encoder wheel cleaned or replaced.
Jan 14, 2009 | Brother MFC 420CN All-In-One InkJet...
HP 7410
do a self test on the printer and see what that looks like.
Apr 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
OKI MICROLINE 320 Turbo Matrix Printer Logo
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
