Question about Samsung SYNC SGH-A707 Cellular Phone
The white tab in the back changed color to red is my phone dead or is there a solution? what made it change can I fix it?
    Guru:
  • 188 Answers
Nah your phone is not dead........it color changed from white to red because your phone was dropped in water or it got wet.
You should change battery and see if your phone works else do this:
  1. Take out the battery of your phone.
  2. Leave your phone in free air for a day or two.
  3. Put the battery back in your cell.
  4. Good lUck......!
Posted on Nov 24, 2009
My fargo printer prints black and white on the back of the card
Possible solution: Change the resin dither from Optimized for Graphics to Optimized for Photos with in the printer driver under the image color tab.
Feb 23, 2012 | Fargo DTC525 ID Card Printer
I have sound, blue and green color, but no red. model R57W46
Change tv to another incomming broadcasting signal coaxal cable wire plug into it,might be lucky,the incomming signal wire is the problems.If it is not the incommming signal coaxal wire plug in.Than the tv RED color gun is dead,might have a dead CRT tube RED color gun.This problems is not easy to be fixed or determine.Should hire a tv tech to troubleshoot and rerpair.
Mar 16, 2011 | Zenith R57W46 57" Rear Projection...
Buzzing noise from back of television
Ur tv colors wheel is going to die soon.U lose colors,tv turn into black and white.It make buzzing,squiling and ratterling noises.The colors wheel is spinning off of it axis,it dead.Require changing the colors wheel.Call the tv repairman to do this job.Must take out many machanical parts even to get to the colors wheel to change it.Never done this before don't atemp this to do this ur self.Tv tech.well charge u more,if he have fix ur blunders.
May 08, 2010 | Samsung DLP HL-P5663W 56" TV
How do you adjust color, color seems too green?
There should be colour settings under the "picture" tab in the menu. In the colour settings you can change the level of green, blue and red (the 3 that make white) Here you can scale the green back to make it closer to equal with blue and red
Jul 06, 2009 | Hisense TL1700 17 in. LCD Television
My nokia n95 wet with water
Open the back case, revealing the battery. You need to look for the small sqare piece of paper, it was originally white, usually changes color to red or purple if it comes into contact with water.
If indeed the color has changed then the phone will have voided any warranty, due to water damage, and the phone cannot be repaired.
May 31, 2009 | Nokia N95 Cellular Phone
Dead Pixels
You cannot fix the bad pixels, it simply means your screen has been damaged OR there was a manufacturing problem (faulty hardware).
The phone should still be under warranty, you need to send it in to be repaired.
Post back for further help (Additional info). Thank you for choosing Fixya!
Mar 29, 2009 | Samsung Glyde SCH-u940 Cellular Phone
No service
What color wires were there ???
What kind of jack, a new one that had...
white blue/blue
white orange/orange
white green/ green
white brown/brown
If so, the white/white blue would go to the same wires.
If you had red/green and black/yellow, the red/green should go to the white blue/blue.
Jan 13, 2009 | Lands Phones
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEARED ON MY SCREEN???
hey, i had the same problem and i fixed it. i took the battery out and saw the 4 golden tabs behind the battery. there was two tabs that u could pull out. i lightly pulled them out a little bit. the problem was that the tabs wouldnt hit the battery to charge it. thats why it put the tri colored screen on the front. also my charger fit into the charging hole in the phone, but it had to be moved around to much that it did not fit exactly. I have been rough with the charger so it moved the inside of my phone around. i put the charger in the phone and moved it around gently around untill the light lit up on the front at the top by the word at&t. after it was completly charged, i turned it on and it worked perfectly. i hope this helps in whoever may have this problem because i know it sucks!
Thanks
Aug 08, 2008 | HTC TYTN GSM Phone
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Samsung SYNC SGH-A707 Cellular Phone Logo
74 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
