Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I have low hardiness in my spa water. What can I do to raise this?
  • 10,515 Answers
Follow the below guide :-
http://www.splashspas.co.uk/spa-accessories/hot-tub-water-balancing.htm
To increase the hardness to the recommended level of 150-400 ppm, add a calcium hardness increaser such as Leisure Time CALCIUM BOOSTER. Too much calcium can cause scaling on the walls and heating elements or cloudy water. To prevent calcium in the water from causing these problems, add a sequestering agent such as Leisure Time SPA DEFENDER.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 24, 2009
Spa Drains Down to Pool Level
install check vales - this will stop the water from leveling off between the pool and the spa
May 22, 2012 | Pool & Spa
How do I fix the bad tube
2012 comes, in order to thank everyone, characteristic, novel style, varieties, low price and good quality, and the low sale price. Thank everyone Welcome to
===== http://www.clothes6.org ====
Air jordan(1-24)shoes $30
Handbags(Coach l v f e n d i d&g) $30
Tshirts (Polo ,ed hardy,lacoste) $15
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,A r m a i n i) $15
New era cap $12
Bikini (Ed hardy,polo) $20
===== http://www.clothes6.org/ ====
Apr 27, 2012 | iLO IWT3206 TV
My dream maker spa at temp outside 40 is heating water till only 80 dont know what to do.
This is common when your Heater element is bad.
The friction of the water moving through the pump typically will raise the water to around 80.
Jan 17, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Other than chlorine what chenmical can you use to shock your pool and avoid any damage to the heat exchanger?
Shocking your pool water in and of itself will not hurt the heat exchanger. Raising the chlorine levels to 10 points over total chlorine is not going to do damage. What damages the exchanger is HIGH concentrations of low pH chlorine via an errosion feeder nearby without an operating check valve or overall low pH over a period of time.
Shock the pool based on the direction provided by the shock product you decide to purchase and keep your water balanced and your heat exchanger will be fine.
John
Sep 06, 2011 | Raypak RP2100 DIGITAL POOL HEATER R265
How to change the preheater in the fuel filter can my truck died and wont start no codes but talk has led me to the preheater shorting out causing the computer to keep the truck from starting
THE FUEL HEATER IS LOCSTED AT THE BOTTOM OF THE FUEL FILTER WATER SEPERATOR ASSEMBLY.REMOVE THE FUEL FILTER WATER SEPERATOR ASSEMBLY, REMOVE THE FUEL HEATER THERMOSTAT MOUNTING SCREWS,REMOVE THE THERMOSTAT FROM THE FUEL FILTER WATER SEPERATOR HOUSING,DISCONNECT THE ELECTRICAL CONNECTOR FROM THE FUEL HEATER,REMOVE THE MOUNTING SCREWS AND LIFT THE FUEL HEATER FROM THE FUEL FILTER WATER SEPERATOR HOUSING.PUT EVERY TRHING BACK VISA VERSA.
Mar 31, 2011 | 2001 Ford F350 Super Duty SuperCab
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Apr 18, 2010 | Intex Automatic Salt Water System for ...
Heater runs 5-10 minutes then blows the breaker
After raising the water level in the pool I had no results. I bypassed the pressure switch and nothing happened so it was not the switch. Then I turned on the current for a few minutes, this moved something as it works now. So I conclude that the problem came from letting my water level get a little low.
Mar 26, 2009 | Raypak Spapak Electric Spa Heater - Els552...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
