Question about Minolta Office Equipment & Supplies
I have a donated di550 with a missing front cover. whre do i get used parts
  • Minolta Master
  • 1,297 Answers
Blocated the microswitch located in the left side upper and the copier is funtionally perfect.
Posted on Sep 27, 2009
Minolta di550 error code c-13fc
Image processing board or the Print head ( What houses the LASER inside the machine they are not talking to each other so that code is displayed. Check the connections , I would go with print head 1st. Di550 is a legacy Minolta machine, might be tuff finding a print head as for Image control board WOW! Home and close front door resets if it comes back need above
Nov 19, 2013 | Minolta Office Equipment & Supplies
Diferential cover leak
In plain site under front of vehicle
Part of transaxle check one you check both
Mar 15, 2013 | 2008 Chrysler Town & Country
Di550 light printing
Directly below the drum section is assemble called the transfer/separation assy. the purpose of this unit is twofold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. use a eraser end gentle I mean gentle clean them. release front lever then push down and pull out transfer/separation assy. remove the guides clean wires, again be gentle, has the drum been replaced, does this happen with printing or copying if only copying clean the mirrors below the big glass, be gentle can use Windex, use of paper towel don't leave any little paper particles
Jun 24, 2012 | Minolta Di550 B&W Laser Printer
97subaru legacy, and both the front and rear lighters aren't working, and would like to know which and whre the fuses are i need to change The location of the fuses
hi the fuses are located under the drivers side (jdm version) on the side of panel under a black plastic cover, just look for the blown one as the locations are all written in japenese
Apr 06, 2012 | 1997 Subaru Legacy
I found a Bushnell 78-9518 telescope. Missing Scopes
You may be able to get parts or have it repaired here:
http://www.opticsplanet.net/bushnell-warranty.html
Jul 11, 2009 | Bushnell Deep Space 78-9518 (675 x 114mm)...
Transporting a washer
Remove the top cover, and put plenty of packing down both sides to prevent the inside parts from moving about, this way it will be o/k to transport it on it's side.
Plz rate my solution.
thanks.
Jan 25, 2009 | Frigidaire FTF530FS Front Load Washer
C13F5 error
There is a small IC board under a cover in the optical secsion near the scanner, open the cover and change that small board, its called IC something, If ya need further info let me know, Ill look up the part #
Feb 15, 2008 | Office Equipment & Supplies
Master Reset?
Page 147 will show you reseting procedures
http://www.copierprofessionals.com/protectedmembers/130914/DI_450_550/DI_450_550/FIELD.pdf
Let me know if this helps. If not I will keep looking.
Nov 21, 2007 | Minolta Di550 B&W Laser Printer
"to test stapler, press staple button" ... Minolta di550 with FN-105 ... HELP !!!
First make sure that you do not have the collate and staple option checked on the printer menuing system or in the print setup on one of the local machines printing to it. Ensure that when auto-staple is not used that the error stops manifesting.
Then, I would check to make sure that you are installing the correct staples, length and width for the model.
Jan 23, 2007 | Minolta Di550 B&W Laser Printer
19 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
