Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Forgot password to access router settings - D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
  • 395 Answers
If you have forgotten the password, press and hold the reset button to reset the router. When you are prompted for username and password. Just input admin as username and password. This should get you back on.
Regards
Posted on Sep 24, 2009
Forgot wi-fi password
if you have access to the wi-fi router, you can reset it to default password by pressing reset button on the router, this will revert it back to the factory settings, including router name and password, the password will be on the router itself.
Nov 07, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Crack password online
Restoring a Netgear Router to Factory Default Settings
Symptoms:
Cannot access the NETGEAR router or access point web interface login screen, or
You have forgotten/lost the password to log into the NETGEAR router or access point (NOTE : This refers to the password required to access the devices administrative interface. If you have forgotten the password required to access the wireless network, you should refer to this article instead).
http://kb.netgear.com/app/answers/detail/a_id/9665/~/restoring-a-netgear-router-to-factory-default-settings
Sep 16, 2013 | NetGear Computers & Internet
I forgot my password
Which password you are looking for?
If you are looking for wireless network password then you will need to access the router setup page and check the wireless settings.
IF you are looking for password to access router settings then default password of Linksys router is admin.
To check the wireless network password see How to find wireless network key WEP WPA
Jan 08, 2012 | Linksys Wireless-G Broadband Router
I forgot my internet password. how do i get it?
What Password did you forget if you forgot your password for your ISP then you will need to call them if it for the access point then just reset it and you will have to set up the security again Reset button is usually located on back of router/access pointuse a toothpick or similar object to depress button for approximatly 10 seconds.
Good Luck!
Jun 10, 2011 | D-Link DIR-615 Wireless Router
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you forgott WEP password in wireless security note down the WEP code it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 08, 2010 | Linksys WRT120N Router
Forgot my password
Sep 06, 2010 | Linksys Wireless-G Broadband Router
Forgot password and user name??
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you want to secure wireless then enable WEP in wireless security enter password there it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 05, 2010 | Linksys Wireless-G Broadband Router
Forgot custom password, have reset router and also
Hi Friend,
You have do a reset for your router
Step 1:Take a pen or a paper clip and insert it into the reset hole and hold it till the lights are getting flashing
Step 2:Once its flashing with out taking the hand from the reset unplug the power cable of the router and put it back after 10 to 20 secs
Step3: Then follow the below link to configure the Belkin router
http://www.fixya.com/support/r4364415-configure_brand_new_belkin_routers
If you have any Clarification please contact us any time
Regards,
Ayyasam
Apr 02, 2010 | Belkin (F5D5231-4) Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
665 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
