Question about GE 27GT616 27" TV
Finding DVD Plugs
I am trying to find the plugs to attach my DVD. I can't find a place to plug anything in. Is it hidden somewhere I can't see?
  • 80 Answers
No it's not hidden but don't fret just open your wallet.
You need what is called an RF Modulator. All you do is connect your A/V component ( DVD ) to the modulator's input jacks, then connect the modulator to your TV's antenna/cable input and select channel 3 or 4 operation.
Your local department or super center should have it. If not you can always go to a Radio Shack near you they will have it.
Posted on Sep 24, 2009
Testimonial: "This explained my question perfectly."
Hitachi Plasma tv cle 980
A few places to look---either there is a opening that faces the rear of set somewhere or it plugs UP (hidden from view) into a opening at or near the rear audio/video in jacks--take a close look.
Jun 17, 2012 | Televison & Video
How to get door panel off to replace window motor
unscrew the handles(door shutting)
take a minus (-) screwdriver and put it between the panel and the body to which it is fixed you will feel the plugs pull the panel from that place there will be about 10 of these plugs hidden to eye as they are attached to the panel from the inside
Feb 22, 2011 | 2000 Toyota Camry
Dear all, I've bought a cat 2/1 alarm and was told by a friend that the alarm will plug straight into a socket somewhere on the bike. I've lifted the seat and there are two plugs there but they don't fit...
Hi i fit another make of alarm, you may need to buy a bike specific loom from acumen, or hard wire it...( the plugs you have found are used by the dealers for diagnostic plugins like re seting error codes, do not remove these plugs)
Feb 20, 2011 | 2006 Honda CBF 1000 ABS
Finding spark plugs
you must have a 4 cylinder engine
remove the top cover that has the engine size on it. It will have the ignition module attached to it as well under it. It will pull off upward will little force when removing
May 20, 2010 | 1995 Pontiac Grand Am
I have the SR6200 and I am finding I have to really crank the volume to get the same sound that I used to have on a lower volume setting----I have not changed anything---any ideas? This is occuring with...
sounds like you have an issue with the cables/leads from the receiver to the other equipment? try buying a new set of cables and/or check that the pins/plugs are in correctly, they may have been disturbed? wiggle the plugs on the leads at the back of the receiver whilst it is playing music/tv and do the same to the rear of the dvd/tv/cable unit. if you get intermittent increase in the volume it is likely that the cable has a break in one of them? good luck
Sep 12, 2009 | Marantz SR-18EX Receiver
Can't find the spark plugs on a 2004 kia spectra gs
If you have the 4 cylinder (which is sounds like you do), you have 2 wires and 4 plugs. The coil has an extender that goes deep into the cylinder, the wire is attached to the side to fire the 2nd cylinder. This is what is known as the waste-spark system.
To change the plugs, remove the cover like you did previously. Next, separate the wire from the coil. Then lift the coil straight-up out of the engine... you will see one plug hidden under there. Lastly, remove the wire and you will see the other plug. Since you have two coils, you will have two hidden plugs, the other two are under the wires.
Since it is a deep drop to the plug hole, replace the plugs by putting a hose over the white part of the plug and gently drop them down into the plug hole. You can also tighten the plugs since the hose will probably have a snug fit.
Since you have aluminum heads, be sure to dab some oil from the dipstick onto the threads of the spark plugs... this will prevent them from sticking inside the head the next time you remove them which saves the threads from being torn out.
I hope this helps.
May 02, 2009 | 2004 Kia Spectra
Spark plugs 24v v6 sri 200 vauxhall vectra!!!!
On vectras they are hidden under a black plastic cover ontop of the engine, but you don't need new plugs for the mot
Feb 23, 2009 | Alera Technologies Cruiser (270118)...
Insignia pd-1020
Go to Radio Shack.  You're going to need an IPod dock that has video playback capability, an av cable with the three av outputs.  Then you will need a mini jack cable that plugs into the video and another mini jack stereo cable for the sound.  You made need a coupler as well.
They only make home cables for Ipod systems.  The other wires will convert the home cables for portable DVD use.
Sep 17, 2008 | Insignia I-PD1020
2005 Camry
Yes I have an 05 Camry and the tune up is due at 36000. I have 40,000 and just looked at my manual. I wanted to consider changing my own spark plugs. I haven't done this in 15 yrears or so. I was rudely awakened by not even seeing where the plugs are located. They cover it all up and there is a condenser or something like that on top of each spark plug. Each item on top of each plug takes the place of a distributor. So if the timing is off it is from your spark plugs and/or these items that attach to each spark plug. They cost abour $ 118 each at discount auto parts. You have 4 of them on the LE.
I think I am going to return the spark plugs which cost about 6.50 each. I will just go get a tune up. Not worth my time to tear everything apart in a confined space take the screws off these condensor or what ever they call them that attaches to the spark plugs. then you pull them out very carefully hoping you don't ruin them. Yuck.
Jul 28, 2008 | 2004 Toyota Camry
Televison & Video Logo
230 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
