Question about NetGear DG834G Router
I have an ipod touch that I am trying to connect to my qwest wireless internet. I have entered the WEP key and it shows that I am connected but when I attempt to open Safari it says that it can't find the server. Can someone help me?
    President:
  • 803 Answers
  1. Turn on your iPod.
  2. If not at the home screen, press home button.
  3. Tap settings button.
  4. Tap wi-fi.
  5. If broadcasting your ssid, choose from the 'choose a network' list.
  6. If not broadcasting your ssid choose "other" under 'choose a network'.
  7. Under 'name' type your ssid.
  8. Tap 'security' if you are using security and select your security type.
  9. Tap the 'other network' button to get back to network setting.
  10. Type in your security password, which is your key in your wireless network setting. Important *you must use key 1* in wireless setting.
  11. Click 'join' after you have typed in your security password.
  12. Your network name (ssid) should show in 'choose a network' with a check mark next to it.
  • Use security with your wi-fi connection.
  • Use the first key password in your wireless network setup screen, key 2, 3, and 4 will cause the iPod touch to not connect even if the password is correct.
Posted on Sep 24, 2009
Trying to connect device to home wireless router and not sure what WEP key is?
The WEP key is the password that is used to connect to your wireless internet. It will be the same one used on laptops, Ipod Touch, and smart phones.
Aug 20, 2011 | Nintendo DS Console
Can't Reconnect to Secure Wireless Network
there is a problem with your WEP key, means the password which is used to enter your router or network. simply delete the network from the network list and connect to the network again and insert the correct shared key.
May 03, 2010 | 2wire 2700HG-B Router (2700HGB)
Need to connect ipod touch asking for passcode ?what's that?
you must remember the code entered when you set up your wireless router, or buy another one.
Feb 14, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Wi fi on ipod touch not connecting
First of all check what is the ip address of your router ,,,default is 192.168.1.1,,,but if it does not work click on start>run>type cmd >hit enter,,,in cammand prompt type ipconfig >hit enter,,,you will get default gateway address on the computer which is connected to computer,,,,type this default gateway in address bar of internet explorer not in any search engine,,,,it will ask for user name and password of router default is leave username blank in password type admin,,,if it does not work then there is no way to check wep key ,you need to reset the router to factory default ,,,and if it does,,,go to security under that there is subtab wireless security ,,you will get this wep key in key1 field,,,
Jan 02, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Tiscali Ipod Touch Connection
Well if the WPA is set now to WEP you need to re enter the WEP key and not the WPA info on your IPOD it it will never connect right.
Jul 08, 2009 | Apple iPod touch
Connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
Will not connect to internet cannot find server
Go into your itouch in settings and wifi.
make sure your wifi switch is on
see if your wireless network is showing and choose it.
enter your wep key and it should connect.
if your ipod is not seeing your network click other
enter the name of your network and the wep key from the bottom of the router and
see if it joins.
good luck
if this helps you please leave a fixya vote
Apr 27, 2009 | Apple iPod touch
My new i-touch will not connect to the internet via the wireless network in my house.
make sure you have your wifi turned on, on the ipod touch itself and if you have a password on your router enter on your ipod when it pops up
Apr 13, 2009 | Apple iPod touch
Connecting Ipod touch 8(GB) to Wi-fi
sometimes the wifi systems only work with windows, the ipod only uses safari and thats what you see on the error. Its connected but safari cannot open it since it is not windows
Dec 13, 2008 | Computers & Internet
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Nov 04, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
811 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
