Question about Canon MultiPASS MP700 All-In-One InkJet Printer
Replaced ink and wrong catridge message comes up
My printer was out of ink and as usual I replaced just the black ( the colors are still empty) and the message reads wrong cartridge. I have bought 3 different cartrdiges so I don't think that is the problem. Do all of the colors need to be replaced in order for this to work? But in the past I have just replaced the black because that's what I use the most?
  • deeval Sep 24, 2009
    Yes it is the right cartridge and if I had the manual I guess I wouldn't be asking for help. Thanks anyway
    President:
  • 803 Answers
What I would do is check your maunal to see what cartridge you need for your printer and purchase this cartridge. If you have not need color cartridges before than you wont need them now. Just make sure you inserted the right ink cartridge for your printer
Posted on Sep 24, 2009
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Hi there, Can I print in Black & White when I ran out one of colour ink catridges??? On Brother website it says that you can. According to their advice the Error message shoud come up on LCD screen...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up you should be able to tell the printer to print in black and white in your page setup or print properties portion when you go to print your page.
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | Brother MFC 6490CW InkJet Printer
Replaced the ink. black works colored does not.
Normally, new catridge has a thin layer close the output of the ink. See that thing. If it close, pull it over, Or.
May be the catridge is not suitable with the printer.
May be the the catridge is quite old and the ink is dry, if it is refill catridge, put several drop of hot water in it.
Hope this may help.
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Epson RX600 will not scan or nuthin' with empty ink cartridges
I cannot help about the Printing problem, because it seems it needs to have all the catridges with some ink to Print.But i can help you about the scan problem.I was having the same issue as you and gave up trying to print, but when i needed to scan i realized the printer didnt let me touch any of the buttons, repeating the same message "change catridge".If you use the EPSON SCAN application that comes with the printer, it lets you scan directly from the PC. It takes longer, dont know why, but at least it scans.I hope it helps.
Jan 10, 2009 | Epson Stylus Multifunction Printer/...
Print trouble
Color images printing in black and white only is a very common problem but not (usually) the other way around. My first guess is that you still have ink in your color cartridge but your black ink cartridge is empty. Usually, you'll receive an error message on the panel of the printer letting you know this, so you might want to have a look. Also, you can open the printer and have a look at the cartridges to see if the black one is empty. If it is, just replace it with a fresh one.
Having said all that, HP.com has a web page that can help you troubleshoot the problem:
Wrong Colors
Hopefully, this is a simple fix. Good luck.
Sep 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Color printing
GO TO MAINTANANCE SECTION IN THE MENU TRY TO TAKE SELF TEST PRINT.
IF IT COMES THEN GO TO NEXT STEP AND TRY TO CHECK THE INK LEVEL OF THE CATRIDGES IF THE INK LEVEL IS LOW DO REPLACE WITH THE GENUINE CATRIDGE ITSELF.
Feb 29, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon MultiPASS MP700 All-In-One InkJet Printer Logo
238 people viewed this question
old marine
old marine
