Question about Hannstar I-Inc iF191DPB 19" LCD Monitor
I-Inc iF191D wont stay on
I have an I-Inc iF191D 19" LCD monitor, that yesterday started making a high pitched whistling sound when its off, that stops when I press the power button. However, after pressing the power button the indicator light comes on saying its on, then after 4-5 seconds turns off again, and this continues until I press the power button again to turn it off. Then back to making the whistle. I plugged it all in, turned on the computer and same on and off problem, however it stayed on much shorter and the screen would flash white. I dont know what to do, and as its less than a year old, I dont want to replace it. Thank you
  • 1,684 Answers
You have a blown power supply. If it is less than a year old its under warranty, send it in for repair. If it is out of warranty our site can show you how repair the internal power supply. Our site is :
www.ccl-la.com/badcaps.htm click on the link at the bottom for monitor repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 25, 2009
Testimonial: "Thank you, your help was the best I was able to get, and I tried very many places."
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
No picture on my philips 42PFL7422D/137 lcd I have already replaced both master and slave boards and my picture returned. After about a month or two the tv started to make a high pitch whistling sound...
do you have sound but no pix?its the video board if you have neither it will be the board where your coax and audio inputs connect...just a matter of getting the right boards off of e-bay GOD bless
Sep 18, 2017 | Philips 42PFL7422D 42 in. LCD TV
High pitched whistling
Try changing refresh frequency, color depth or resolution (wait for the whistle to appear before testing). Admittedly, you might have to give up some image quality - less colors, or less resolution. There is probably a problem in the TV syncing mechanism - if you can, try getting it replaced. "High pitched whistles" in video and TV hardware are usually harbingers of bad news.
Aug 24, 2009 | Samsung SyncMaster 245T 24 inch LCD...
Turns on then gives a High pitched Screech then shuts down even after totally unplugging it and reconnecting it blinks on then Screeches then turns off rinse repeat
are you talking about just the monitor of the computer as a whole? if you are talking about the computer then, there is something loose inside the case, which is causing the high pitched sound.
Jun 27, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Acer al1916b high pitched noise when on standby.
Sounds like you could have an open ground? Also might check the wiring to see if you have a faulty connection in VGA cable or power supply cable
Jul 24, 2008 | Acer AL1916B 19" LCD Monitor
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Open Questions:
Hannstar I-Inc iF191DPB  19" LCD Monitor Logo
1,047 people viewed this question
Top Hannstar Computers & Internet Experts
 Russ Hill
Russ Hill
memman
memman
Level 1 Expert
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
