Question about Dewalt 3800 PSI Pressure Washer
DeWalt 3800 Pressure Washer Runs 20 min then quits.
Runs great for 20 mins, then power loss. After "cool down" machine okay.
    Problem Solver:
  • 8 Answers
I have the same problem and even have the issue with gas cap off.
Posted on May 27, 2010
Washer runs great for about 3-4 min than shuts down. Motor runs as long as I do not ingage the nozzle.
Recently I have a similar problem, with a easy solution, just don't push the accelerator nob all the way, leave a 1/4 before reach full power. Apparently some times there is a bad calibration an make the carburetor over flow and lost power.
Sep 11, 2014 | Garden
The engine runs but the water will not come out under pressure
You must have blown out the cones (thats how the water gets compressed inside of pump) in the water pump-
You could try this though on the back of the washer right on top of the water pump is a black knob about the size of your hand that knob will adjust the pressure try turning it and see although I doubt that is the problem-
A pressure washer is not like a compressor you HAVE to pull the trigger every minute NEVER let it just sit there running without pulling the trigger to release the pressure that Dewalt 3800 psi washer you have is a great machine in fact we own 4 of them and they are pretty powerful and easy to damage if left running alone.
TY,
Perry Tradesman
Sep 05, 2014 | Dewalt 3800 PSI Pressure Washer
Loss of power
Loss of power after running for a while can be caused by anything from a partially clogged catalytic converter to engine overheating due to a faulty engine cooling system. Lots of other things can cause it as well.
Mar 18, 2012 | Cars & Trucks
Pressure washer problem
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a cloged vent, !!
Feb 18, 2012 | Garden
Dewalt DPD3800 pressure washer starts and runs fine. After 5-10 minutes of washing the engine quits. It will not start until it cools. The engine will start after a 10 minute cool down. It will run and...
I have the exact same pressure washer and have had the same issues with it. The cure for me was to simply run the washer with the gas cap loose. For some reason the fuel gets vacuume locked and stops flowing into the carb. The fuller the tank is it seems the shorter the time is between the time it starts and the time it shuts off. Or you might find a way to vent the cap. Hope this helps.
Jun 06, 2011 | Dewalt 3800 PSI Pressure Washer
Dewalt Pressure washer keeps shutting off for no reason. plenty of gas and oil, water running to it. starts fine and as soon as I start spraying it shuts down.
Had a similar issue with my dewalt 4200 pw. Unit starting shutting off after spraying for about 5 min. Then difficult to restart, but would start again eventually only to shut down a few min later. Had new engine oil, new pump oil, good gas. I changed the spark plug and unit runs great again!
Aug 08, 2010 | Dewalt 3800 PSI Pressure Washer
Must wait 30-40 mins to restart engine
Check your manual to see if it call for premium or regular. Premium has less energy per gallon and is designed for higher compression engines. What makes it "premium" is more anti-knock compounds - not better quality or performance. Sounds like a vapor lock problem that resolves as the engine cools. Regular gas may help with that.
May 03, 2010 | Briggs & Stratton 3000 PSI Pressure Washer
Dewalt 3800 PSI Pressure Washer Logo
722 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
