I have a 1988 FWD truck mounted 150S Condor aerial lift, and the Hydraulic hose in the column blew off the crimped connection, why would it do that and how do I get at the connection at the top end? Is there shop manuals available for this unit? Thanks. Linden. lindenh@shaw.ca
  • lindenh@shaw Sep 24, 2009
    I will check with one of the dealers, but, I was hoping for a step by step solution. I'll try to let you know!!! I'm surprised at the reason for the hose to pop off, because I never added oil to the reservoir and I've used this unit for the past 6 months or so!!!!
    Linden.
  • lindenh@shaw Sep 26, 2009
    Thanks, I may have other questions about this unit.
    Brigadier General:
  • 4,090 Answers
Cant help you with a workshop manual Linden, but overfilling the hydraulic reservois will cause it to blow off under strain. Usually the top connection is under a removable plate that can be accessed for service and replacement.
Try contacting the agent for the lift system to see if they can supply you one or at least tell you how to access and remove the hose.
This is the only raven manual I have
http://www.ravenprecision.com/Manuals/pdf/016-0190/094A.pdf
If you need additional assistance, contact your local Raven dealer or the Raven Customer Support Center at
1-800-243-5435.
Please rate the help++++Thanks for using FIXYA
Posted on Sep 24, 2009
  • dennis bullard Sep 24, 2009
    Hi Linden,l Thanks for the feedback.
    Well the only other reason to pop a hose that i know of is if it was crimped at a weak point in the hose. This is rare but i have had it happen on a FEL Massy Ferguson on two remotes. A bad batch of hose was used to replace two essential lifters and both blew after a few months. Maybe this is what has happened to you, an accident waiting in the wings.
    We place too much faith in RAMS and hoses, That's one reason I won;t go on those show rides, most are relying onj a simple seal to hold them upside down and spin their brains out
How do i replace the clutch cylinder on my 2002 chevy s10 extreem
loosen the hydraulic hose at the end of the cylinder . undo the mounting bolts and lift the cylinder clear . unscrew the hose out of the end of the cylinder . lift out. Replacement is the opposite but before you mount the cylinder make sure that the push rod is inserted back into the cylinder.. Fit he bolts and tension up tighten the hose . You should have screwed it in properly before mounting the cylinder and now it is just a matter of tightening it up. refill the master cylinder with fluid and with the help of a friend proceed to bleed out the air . Keep pumping and bleeding until you have a firm clutch pedal.
Feb 14, 2014 | Cars & Trucks
I have a 97 olds 88 how do I change the ignition switch with diagram
up under dash, mounted basically on the side of the steering column
2 screws hold it to the column. sometimes easier to remove the nuts holding column up to dash, lower column down some till wheel on seat.
You remove the 2 small bolts holding switch to column, then there is a rod in the back for the key. Lift switch off rod, Alig new switch back on rod and mount new switch back on the column
It is adjustable to need to eb 100% you have it adjusted so it does NOT start in reverse or any other gear. Only park and neutral
its the top left in picture, shown.. tilt and non tilt very clse to same
Oct 18, 2013 | 1988 Jeep Cherokee
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
How to remove a heator core from a 2001 dodge caravan? do you have to take the dash out? or just the bottom pannel.
The 2001 Dodge caravan has 2 heater cores - front (the main one), and the rear. Removal of the
rear heater core is a whole different procedure than the front.
Front Heater Core - Removal and Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Align the wheels in the straight-ahead position.
  3. Disconnect the negative battery cable.
    CAUTION Before working around the steering wheel or the instrument panel all 2 minutes to pass to allow the air bag module to discharge.
  4. Drain the cooling system into a clean container for reuse.
  5. Remove the steering column, by removing or disconnect the following:
    Lower left side steering column cover Parking brake release cable from the parking brake lever 10 steering column cover liner-to-instrument panel bolts and the cover liner
  6. Rotate the key to the LOCK position; then, rotate the steering wheel to the LOCKED position.
    Gear selector cable and its mounting bracket as an assembly from the upper steering column mounting bracket 2 instrument cluster trim bezel-to-instrument panel screws, retaining clips and bezel 2 steering column shroud-to-steering column screws and the shroud Steering column-to-intermediate steering shaft coupler
  7. Loosen but do not remove the 2 lower steering column mounting bracket nuts/washers.
    2 upper steering column mounting bracket nuts/washers Steering column assembly from the vehicle
  8. Remove or disconnect the following:
    Instrument panel-to-chassis harness interconnect and bracket Lower silencer boot, at the base of the steering shaft
  9. Working in the engine compartment, pinch off the heater hoses.
    Heater core cover. Position some towels under the heater core hoses. Heater core plate and the hoses
  10. Depress the heater core retaining clips.
  11. Lift the accelerator pedal and slide the heater core past it.
  12. Depress the brake pedal and remove the heater core from the heater/air conditioning housing assembly.
    Fig. View of the steering column assembly
    Fig. View of the interconnect and bracket
    Fig. View of the front heater core assembly
To install:
  1. Depress the brake pedal and install the heater core into the heater/air conditioning housing assembly.
  2. Lift the accelerator pedal and slide the heater core past it.
  3. Install or connect the following:
    Heater hoses (using new O-rings) and the heater core plate Heater core cover Heater hoses clamps, working in the engine compartment Lower silencer boot at the base of the steering shaft Instrument panel-to-chassis harness interconnect and bracket
  4. Install the steering column assembly by installing or connect the following:
    Steering column assembly, carefully into the vehicle. 2 upper and 2 lower steering column mounting bracket nuts/washers. Torque the nuts to 105 inch lbs. (12 Nm). Steering column-to-intermediate steering shaft coupler and tighten the pinch bolt to 21 ft. lbs. (28 Nm) 2 steering column shroud and the shroud-to-steering column screws Bezel, the retaining clips and the 2 instrument cluster trim bezel-to-instrument panel screws Gear selector cable and its mounting bracket as an assembly to the upper steering column mounting bracket 10 steering column cover liner and the cover liner-to-instrument panel bolts Parking brake release cable to the parking brake lever Lower left side steering column cover. Lower left side steering column cover
  5. Refill the cooling system.
  6. Connect the negative battery cable.
  7. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Jan 02, 2011 | 2001 Dodge Caravan
I have a 1992 Crysler Imperial. The ABS light is on and the ABS pump runs all the time. Help.
Either the ABS Module is bad or the Pump is bad--- Pump REMOVAL & INSTALLATION 1989-90 Models
  1. Disconnect the negative battery cable. Depressurize the hydraulic accumulator. CAUTION
    Failure to depressurize the hydraulic accumulator, prior to performing this operation may result in personal injury and/or damage to the painted surfaces.
  2. Remove the fresh air intake ducts.
  3. Disconnect all electrical connectors to the pump motor.
  4. Disconnect the high and low pressure hoses from the hydraulic assembly. Cap the spigot on the reservoir.
  5. Disconnect the shift selection cable bracket from the transaxle and move it aside.
  6. Loosen the nuts on the 2 studs that position the pump/motor to the transaxle differential cover.
  7. Remove the retainer bolts that are used to mount hose bracket and pump/motor. The engine inlet water extension pipe is also held in position by these bolts. NOTE: Do not disturb the inlet water extension pipe, or engine coolant will leak out.
  8. Disconnect the wiring harness retaining clip from the hose bracket.
  9. Lift the pump/motor assembly off of the studs and out of the vehicle.
  10. Remove the heat shield from the pump/motor, if equipped and discard. To install:
  11. Place a new heat shield onto the pump/motor bracket, using fasteners provided.
  12. Install the pump/motor assembly onto the studs.
  13. Install the wiring harness retaining clip onto the hose bracket.
  14. Install the retainer bolts to the hose bracket and pump/motor. Tighten securely.
  15. Tighten the 2 nuts until secure.
  16. Install the shift selection cable bracket onto the transaxle.
  17. Connect the high and low pressure hoses to the hydraulic assembly and tighten to 13 ft. lbs. (17 Nm).
  18. Attach all electrical connectors to the pump/motor.
  19. Install the air ducts.
  20. Readjust the gearshift linkage, if it was disturbed.
  21. Connect the negative battery cable and check the assembly for proper operation.
1991-95 Models
  1. Disconnect the negative battery cable. CAUTION
  2. Depressurize the brake system.
  3. Remove the fresh air intake ducts from the engine.
  4. Remove the clip holding the high pressure line to the battery tray.
  5. Disconnect the electrical connectors running across the engine compartment in the vicinity of the pump/motor high and low pressure hoses. One of these connectors is the one for the pump/motor assembly.
  6. Disconnect the high and low pressure hoses from the hydraulic assembly. Cap or plug the reservoir fitting.
  7. Disconnect the pump/motor electrical connector from the engine mount.
  8. Remove the heat shield bolt from the front of the pump bracket. Remove the heat shield.
  9. Lift the pump/motor assembly from the bracket and out of the vehicle. Fig. 1: The pump/motor assembly mounts to the top of the transaxle case and is covered by a heat shield 86729g75.gif
    To install:
  10. Fit the pump motor assembly onto the bracket; install the heat shield and its retaining bolt.
  11. Install the pump/motor electrical connector to the engine mount.
  12. Connect the high and low pressure hose to the hydraulic assembly. Tighten the high pressure line to 145 inch lbs. (16 Nm). Tighten the hose clamp on the low pressure hose to 10 inch lbs. (1 Nm).
  13. Connect the electrical connectors which were removed for access.
  14. Install the high pressure line retaining clip to the battery tray if it was removed.
  15. Install the fresh air intake ducts.
  16. Bleed the brake system.
Oct 07, 2010 | 1991 Chrysler Imperial
Motor mount, front right, solid or hydraulic?
Hello wrygrl...The OEM (orginal equipment) passenger side motor mount for the 1988 olds ninety-eight was a hydraulic type. After market "solid" type mounts are available for replacement...either type will work. Shop around and get some price quotes, i believe westar makes a solid type mount that sells for around 22 bucks.
Hope this answers your question. Have a safe and happy memorial day weekend.
May 21, 2009 | 1988 Oldsmobile Ninety Eight
High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Mar 11, 2009 | Garden
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
Jan 04, 2009 | 1989 Ford Mustang
Heater core
18901fc.gifHere is an exploded view of the heating/air conditioning blower box. This contraption is located on the passengerside under the dash. I've changed heater cores on other cars but never worked on a caravan so not sure how difficult it'll be. You may need to remove a few cover panels to access this and the heater core #22 is located behind the distribution box #6 containing parts 7-18 and hopefully comes off as a unit. I wouldn't want to put it back together just looking at the pic. You may just need to remove the heater tube cover #4 to access the connections and slide out the core.....NAH couldn't be that simple!!! Hope this was of some help. Good luck.
Oct 18, 2008 | 2000 Dodge Caravan
Power steering leak
Check the pump front seal, Wipe down the hoses and check the crimp fittings for leakage Also look carefully at the steering gear, the fitings and pitman arm seal ( this one is on the bottom) and the seal where the steering column goes in.
www.aceautomotive1.com
Aug 03, 2008 | 1988 Toyota Pickup
Computers & Internet Logo
David Payne
David Payne
