Question about Cycling
Clicking noise when peddling - Cycling
    Problem Solver:
  • 5 Answers
Turn each peddle in turn( peddle bearings) Check main crank bearings some times locknut comes loose, or wheel bearings.
Posted on Sep 27, 2009
Noise when you press the clutch peddle.
you will have to take it apart again then see if it all alined right
Jan 06, 2014 | Garden
Brakes click when the peddle is pressed while on and in park
IF IT ONLY MAKES THE NOISE IN PARK THEN IT'S FINE ITS THE SWITCH THAT ALLOWS YOU TO SHIFT INTO GEAR
Nov 27, 2012 | Kia Sephia Cars & Trucks
Peddle make noise
The pedal is going bad. With wear they misshape and the bearings don't roll properly. Replace the pedal
Jun 24, 2012 | Schwinn Cycling
I was rideing when all of a sudden I heard a POP sound and my peddles wouldn't peddle any more!.......my peddles free wheel like the chain is off but it is not!......when I spin the Back wheel forward,...
Possibly. The pawls probably exploded. Not knowing what type of rear wheel/hub you have it's impossible to say but a Bike Shop would spot the cause in a heartbeat. The repair may involve something as simple as a spritz of lube in the right places to a complete new rear wheel (as hub replacement involves a lot of labor rebuilding the wheel and may not make economical sense).
Take it to a shop for a look-see.
Jun 30, 2011 | Cycling
When the bike is peddled there is a clicking sound. Is this normal? The bike hasn't been used for about a year.
I think the clicking noise is caused by one of two common issues. The easiest is that the little black computer pickup is too close to the magnet located on the right plastic piece on the right side of the wheel and everytime the wheel makes a full circuit while peddling, that little black piece clicks as it actually hits the magnet. If that's the case, then pull the black magnet sensor away just 1/16 of an inch aways so it will not hit the magnet everytime it passes the magnet. You can tell what's causing the clicking noise by getting on the floor and pushing the pedal around with one hand slowly and looking closely at the tow places I will mention to determine where the clicking noise comes from and then making the adjustment to stop it. the other place the clicking can come from is the chain rubbing against the metal on the left side. It might be hitting the TOP of the metal cage when cycling OR the BOTTOM of the metal shield which covers the pedal assembly. Look closely at the left side of the bike while peddling the bike slowly to see if the noise is metal against metal. You can shift the cage slightly to take the pressure of the cage from scrapping the chain by sitting down in front of the bike facing the cage and placing both feet onto the left & right supports (they're what hold the bike up) and you grab the little black wheels on both sides with your hands and push down slightly but firmly to shift the cage a bit and it will move up or down depending on where the chain is scrapping it when you cycle. That cage will shift slightly over time and it can make a loud noise when it scrapes the chain. I hope this helps. If not, give me a reply with more details and I'd be glad to help you isolate and fix the problem. Leave postive comment on fixya if you like my solution. Luke terpcafe@yahoo.com
Jan 16, 2011 | Schwinn Original Airdyne
Schwinn 201 recumbent bike makes clicking noise
Check the tightness of the crank bearings, also the crank fastening nuts (on axle) If its the gears you may have to turn the screws on the rear derailleur to adjust the tracking. The same as the front. Your question is kind of vague so its hard to pinpoint the clicking noise. Could even be a stone in the tire??lol
Feb 20, 2010 | Cycling
When im riding my BMX,a loud clicking noise comes from my peddles
might be something to do with the postioning of the sprockets?
Jun 26, 2009 | Mongoose 20-Inch Gravity Games BMX...
Cycling Logo
129 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
