Question about Garden
I have a Toro LX 420. Bought in 2006. Put a new battery in and I get a click sound under the seat where the battery and solenoid are when I turn the key. Is it the solenoid or the starter?
  • 389 Answers
Most likely it is the solenoid especially if the battery is new but the only sure way to tell is to test the battery with a volt meter for 12 volts or more or use a HEAVY jumper wire and cross the two large posts on the solenoid. If it cranks when you cross them, replace the solenoid. don't hold the wire on too long, it will get hot and melt the insulation
Posted on Sep 24, 2009
Why doesn't my toro timecutter z5030 start?
First make sure all battery cables are clean and tight and it could be the starter or starter solenoid if battery is ok..
Apr 25, 2016 | Toro Garden
I recently had a new steering gear replaced on my Toro LX 420 and now it won't start. The mower was dropped off after being repaired and my wife put it away with no problem. The following day my son went...
Sounds like an interlock is not closing. Perhaps one was knocked loose during the maintenance. Make sure blades are disengaged, mower not in drive and someone in seat.
Oct 05, 2014 | Garden
Does the hour meter in a toro tractor lx 420 show Tenths?
Best way to check that out is to run it for six or seven minutes and see it the number changes by .1 and if it takes an hour of running to move the nkmber you will know that it reads hours nit tenths.
Sep 21, 2014 | Garden
Toro lx 420
sounds like short to groung earth check wire back its possably chaffing on metalwork some were
May 25, 2014 | Garden
Toro lx 420 wont start, sounds like starter wont engage jst a clicking sound. I put a new battery and solenoid in and still the same
starter motor i would suspect. try hitting it with a hammer to jar it into life. im sure its the starter motor.you could try running a positive from the battery to the positive on the starter motor to see if it turns if it does not replace srtmotor
Mar 08, 2014 | Vertex Ride On Mower
I have 1995 toro ridding mower.i got it not working an the battery was not charging so i got a new battery an ones i hooked it up every thing work bu did not start an it just makes a clicking noise when i...
Test the battery with a volt/ohmn meter to ensure it reads at least 12-14 volts. Check all the safety switches located underneath the seat & the mower deck engage handle is disengaged. Check all battery wire connections are soldi, not corroded. Check wiring on starter solenoid from battery & to key switch.
Oct 24, 2010 | Toro Lawn Mower With Toro Power Tools
My 2006 troy-bilt superbronco wont start. There is only a clicking sound that comes from under the seat. Batery is fine and the starter is new.
There is a "starter" solenoid that closes when the ignition key is turned to the start position.
Follow the positive (red) battery cable from the battery post to the solenoid. If you have a 12 volt test light or volt meter, check to see if you have 12 volts on the battery side of the solenoid then turn the key to the start position and see if you have 12 volts on the starter side of the solenoid.
I believe you have a starter solenoid that has gone bad.
Good luck, let me know.
Regards,
Jun 30, 2009 | Garden
Won't start, just clicks
I'm not familiar with this Toro Model, but that click sound probably is the starter solenoid engaging. Have you checked the wiring from the battery to the solenoid and from the solenoid to the starter? Also, check the ground connection on the mower frame.
You may have a bad starter motor. You can by-pass the solenoid by - placing a heavy gauge wire from the POSITIVE battery terminal directly to the STARTER terminal, where the heavy wire is attached. Be careful NOT to ground out the wire from the battery.
If the starter turns - it's a bad solenoid. If it does not turn - it probably is a bad starter motor.
May 03, 2009 | Garden
Garden Logo
431 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
