Without knowing its history, is there any way to tell what condition a turntable stylus is in? I have several older cartridges and styli (?) and don't know which to try and use in my turntables. Thanks!
  • Audio Player... Master
  • 5,151 Answers
I would have thought the only way would be to look at it under a powefull lens, such as the ones jewellers use. If you have a known good stylus you can then compare it with the ones you don't know.
Posted on Sep 25, 2009
What would it cost to purchase a styli/needle for Sherwood DEK7-U?
All you need to do is look at the cartridge and find the make and model number of it. Put that into google search and the information on the stylus should come up.
Jul 03, 2014 | Audio Players & Recorders
Need stylus for 2200 where from ?
You can order them online from Zsounds, they have some of the best prices anywhere. Here is the link to the page that has styli and cartridges.
http://www.zzounds.com/cat--DJ-Turntable-Cartridges--2450
Mar 24, 2011 | Audio Players & Recorders
Replacement Cartridge and stylus for Technics SL-D1 Technics Turntable
That turntable, like many others, has an S-shaped tonearm with a removeable headshell. You can use any standard screw-mount cartridge as a replacement. Which one you buy depends on what you want to spend and your intended use. If you're a DJ you'll need a more rugged cartridge than you do for listening at home, for instance.
One company I buy lots of parts from is Parts Express. Here's a link to their styli/cartridges pages. If you have the original cartridge and stylus, you can check if they have the exact replacement. Otherwise you can browse the other choices. You can find many other sources as well, and you may have an audio shop or musician's store in your area who stock cartridges.
Jan 02, 2011 | Technics SL-1200MK2 Turntable
I need a repalcement for a stylus 402-M208-165
You 'll need to know the brand of cartridge that the stylus is for
Go on line - NeedleDoctor.com. They have dozens of listing for replacement styli.
Jun 28, 2009 | Audio Players & Recorders
Turntable arm slides across record, Am. D.J.-1500
See what type of cartridge is installed in the arm. Manufacturers use common cartridges in turntables, such as Stanton, Shure etc. Detach the head shell from the arm (it usually slips right off via a locking ring and four-pin mini plug) Look for the manufacturer and model number on the cartridge. No need to remove it from the head shell. On most modern cartridges, the stylus (as they are called, rather than the needle) simply slips off and on. No need to remove the entire cartridge (via screws) and re-align it. In fact, many DJs bring a set spare cartridges and styli on a gig, already mounted in head shells, and simply interchange them as needed. When you have the make and model of the cartridge, go to Radio Shack or use their website to order a new one...or  two. Or go to Google and enter "phono stylus" as your search term. You will find reasonably priced styli for nearly every cartridge imaginable. I operate 50 year-old turntables and am able to find replacement cartridges and styli on line. Ebay also has a number of listings, by make and model of the cartridge. When the new stylus arrives, observe how easily the old one comes out of the cartridge- usually pull and slide - and slide the new one in. Re-insert the head shell on the arm, tighten the locking ring, and you're good to spin!
Jan 06, 2009 | Audio Players & Recorders
STR8-60 stylus
I suggest you contact the MUSONIC web site. They specialise in cartridges and styli.
Dec 20, 2008 | Stanton STR8-60 Turntable
Magnavox Stylus
We need to know the model number of the CARTRIDGE itself. Doesn't matter what turntable you have. All that matters is what cartridge is mounted on the turntable, so that we can match the correct stylus. The stylus/needle connects to the Cartridge:
As the diagram shows, the stylus mounts to the cartridge, which then mounts to the headshell. This headshell is then connected to the tonearm (tube).
So, if you look at the cartridge you should be able to see the model number. If not, there is no way to match up the stylus, as ther are literally THOUSANDS of styli on the market. I would suggest purchasing a NEW cartridge/stylus combination. The following should fit your model:
UNIVERSAL MOUNT CARTRIDGES
- Davis
DJ Pro Audio
www.djproaudio.com
Aug 10, 2008 | Philips Audio Players & Recorders
Search for a replacement stylus on my dad's Grundig stereogram RC400GB
This is a VERY VAGUE description. I can name about 30 styli that fit this description.
More than likely the original replacement stylus is no longer available. You'll probably have to purchase a new cartridge assembly. The following should fit your model, however, if you can provide me with the model of your turntable, I can find an exact fit.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 07, 2008 | Audio Players & Recorders
Low Volume from right speaker of entertainment center - turntable only
Hi There thanks for your very good desctiption of the problem it really helps to have a lot of detail...
There are Mono and stereo types of stylis cartridges and it sounds like you have a mono equipped into a stereo amplifier..
If there are 4 small coloured wires visible under the stylis then
its a stereo stylis and should work, have a close look and maybe one of the small wires has dropped of the small pins on the back opf the stylis cartridge.
If there only two wires visible then its a mono cartridge and this is why you only have sound from one channel..
So answer is wires dropped of the stylis.
or
Wrong type of stylis cartridge.
or
if there are four wires and thay all look connected then perhaps the stylis is faulty and you need to replace it...
Cheers from YU BEUT
Feb 02, 2008 | Audio Players & Recorders
19 people viewed this question
 Grubhead
Grubhead
