Question about Garmin (010-00583-00) for nuvi 750/760/770
No Voice (sound) even when volume is at 100% - Garmin (010-00583-00) for nuvi 750/760/770
    Problem Solver:
  • 10 Answers
What sounds are you expecting? GPS only throws direction when there is going to be a turn ahead. most of the time it is silent.
If it is MP3 Player, there are 2 volume settings, Master and Audio check both are non-zero
Also check (if it has FM transmitter), you might have diverted the sound to an FM Station. You should see that option as well in the volume setting.
Posted on Nov 06, 2009
Volume keyboard
Go into function and look for the volume setting for your main voice - could be R1. This will give a numeric value of 127 or less. It sounds like you need to increase it, try 100 as that is usually sufficient.
Dec 27, 2013 | Yamaha DGX230 - Digital Piano
No sound but screen works
turn up volume
if not, good now, its dead.
or is in mute mode, ever read the manual?
its on line , google finds that in 1 second flat.
my old cobra (gave to sis at retirment)
did: voice, (X band, K band in japan like voice)
and no voice
and tones only
and totall silient,
all 100% programmable.
RTM it be a revelation. i promise.
Jul 28, 2013 | Cobra Vehicle Parts & Accessories
No sound reception even with volume at 100%
microphone not working voice not enter whats the problem
Dec 25, 2012 | Computers & Internet
I cant hear any sound
There seems to be a problem with your phone's ear speaker. Are you 100% sure that your sound volume is raised? If it is not the volume setting bring the phone to a phone store. Or contact the manufactirer for service under your warranty.
Mar 12, 2012 | Samsung S8300 Ultra Touch platinium-red...
The voice on the gps sounds weak like its dying out. i can't understand driving instuctions
sounds like you have it lower on the master volume
Try this... Tools.....Settings...Volume...press it ..now you will see ...Master ...Navigation.....Media make sure the Master is higher in percentage I have mine at 100% and keep my Media at 70% Navigation 100%
Nov 06, 2010 | GPS
My garmin nuvi 205 stopped talking even though the volume is on 100%. What happened and how do I fix it?
First press the speaker symbol and check that the volume is not down fully or that the mute box is not ticked. If it is press the mute box to untick it or increase the volume. Otherwise follow the instructions below.
1. Press Tools, then press Settings (or Locale on some models), then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
2. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 1 above.
Oct 05, 2010 | Garmin GPS
No voice. Volume bar shows 100% the bar is not
I assume you checked that the mute box is not ticked. If not check it at the same place as the volume. The most likely cause is that there is no voice selected. To select a voice, press Tools, then Settings, then Language, and then Voice. If a voice is not ticked then press one to select it.
It's possible that the voice files have been corrupted and will not work. IF this is the case connect your satnav to your computer and it should automatically download the latest version of webupdater from the garmin website. When updated you will have the option to download voices. Select the ones you want and follow the prompts and they will be downloaded to your satnav. You may then have to to repeat the voice selection process described in paragraph 1 above
Aug 02, 2010 | Garmin nuvi 885T GPS Receiver
There is no sound and I've made sure the volume is at 100% and the mute is unchecked
could be that there is no voice selected go to the voice settings and select a voice hope that helps
Jun 21, 2010 | Garmin nuvi 1200 Car GPS Receiver
Garmin Nuvi 265 wt...how to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
Sound card driver problem
If you are using xp
Go to control panel
Click on sounds and audio devices
click on voice
See voice playback?
click on volume make sure there is not a check mark in mute under microphone
Do the same for voice recording
and check the volume levels on both
Hope this helps
Oct 20, 2007 | Computers & Internet
Garmin (010-00583-00) for nuvi 750/760/770 Logo
348 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
