Question about Samsung SD 616T Internal DVD Drive
Windows cannot load the device driver
My samsung sd-616e shows up on my computer with a yellow sign and message says Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
  • 909 Answers
You need to right click on the device, from the view with the yellow triangle, and update the driver or roll back the driver.
failing that , download driver max and it will find the driver for you.
Posted on Sep 30, 2009
Samsung dvd 616e driver is missing
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 09, 2012 | Microsoft Windows XP Home Edition Service...
I installed YouCam 4.1 in my HP laptop boot after installing it showing you dont have the compatible VGA hardware or drive to run you cam what can i do?
maybe the problem is in your laptops hardware, maybe the you video cards memory is not compatible on the webcam that you buy,or maybe try to check if your webcam has a driver installed on your laptop. to check right- click on my computers icon the select properties, then choose hardware tab and choose device manger this will show all the hardware installed on your computer and all the hardware that needs a driver, usually the hardware that needs a driver is in color yellow and has a question mark sign.. hope this may help you
Jul 26, 2011 | HP VGA Webcam
I have a dell dimension 8300 computer/ windows XP OS with a Samsung Sd 616e internal dvd Rom Drive. When I insert a dvd or CD nothing happens, except a whirring sound of continuous spinning. Also, when I...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 06, 2010 | Samsung SD 616E (729507925578) Internal...
Samsung SD 616E drive not recognized by PC
Check in the BIOS if the interface/port to which you're connecteing has not been disabled. Most bios ' access by pressing del shortly after startup before Windows has started loading. Others access by pressing F1 or F2. (It should indicate what is needed at the bottom of the screen at startup).
Jul 26, 2010 | Samsung SD 616E (729507925578) Internal...
I am trying to install windows 7. I get to the
try selecting custom installation instead of upgrade. if same error occur there's a problem in your windows 7 cd. some of the files inside is corrupted
Mar 28, 2010 | Samsung SD 616E (729507925578) Internal...
Other devices yellow sign centrino t41
If you recently added a new piece of hardware or have a usb device in the computer these may come up with the yellow caution if there is no device driver loaded for it. You can go online to windows update and let it search for updates and when it is ready to show the results, instead of hitting express hit custom and that will show you all the optional upgrades including all your hardware. Click all the boxes by hardware items and let windows download and install the updates. This may or may not get rid of the caution....it might also mean that you have a piece of hardware that has failed or the driver is corrupt, You can choose to hit uninstall on that particular item and reboot, when windows reboots it may be forced to search windows update on its own to find a compatible driver.
Dec 02, 2009 | IBM ThinkPad T41 Notebook
DVD-ROM of my laptop is not working
What is the specs of the laptop?
Feb 10, 2009 | Toshiba Televison & Video
Samsung dvd-rom 616E won't play sounds
I decided to check to see which video player programs were already on my computer. I have a Dell, so there were several that came preinstalled.
Did I mention that Windows Update had installed several new fixes recently?
My toolbar no longer worked like it did last week, that was a clue.
2 of my programs were no longer in the programs list, Interplayer and Power DVD were missing.
I went to the Power DVD site and downloaded the latest update.
Now my DVD player works fine.
I don't know why RealPlayer or Media Player didn't work, even with the updates.
I don't care, as long as something works.
I could have tried Winamp too but Power DVD worked and I didn't try anything else after that.
It doesn't have to be a problem with the hardware, but could be the software.
Nov 23, 2008 | Samsung SD 616E (729507925578) Internal...
Drivers cannot be loaded...windows does not recognize monitor
I think after your crash you are missing the drivers for your graphics card and not the display. Check what kind of graphics device you have and see if you can find the drivers for that.
Sep 20, 2008 | ViewSonic VX1945WM LCD Monitor
Samsung SD 616E Internal DVD not working
I have the same problem, wont read anything in the drive. It is a master and there is no slave dirve so its not that, jumpers etc checked, drivers, cables. Just wont work.
Dec 14, 2007 | Samsung SD 616E (729507925578) Internal...
Samsung SD 616T Internal DVD Drive Logo
359 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
