Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Gas broiler won't light
Yesterday we had an appliance repair service man look at our gas broiler that won't light. At first he said ''you have a bad Ignitor (it was new)' so he changed it out just to confirm his hunch. (Unit was getting only 1 ohgm when he tested it). Changed ignitor, still no change--broiler won't light while ignitor glows. He left telling me that we needed to replace the control unit. Before spending hundreds of dollars, is he correct?
PS, they wanted $275 for labor and material for the ignitor so the control unit is going to be really high. Actual model no is 75879
  • 1 more comment
  • afisc2910 Sep 25, 2009
    The tech put a meter on each wire leading to the igniter and they only read 1 amp or ohm (?). Yes, the igniter is round and the same style as the original. Two weeks ago I changed the igniter for a cost of $35.00 plus my time. When it didn't light the broiler I called this company. The tech did mention to me that he was trained in HVAC and not appliance repair. I lacked confidence in his ability yet had to pay $75.00 for the service call and his assurances of 99.5% that the Timer ERC was defective. I can get this part for around $160.00 on the internet but am hesitant to make the purchase
    without confidence.
    Have not checked the line voltage but will do so tomorrow.
    The Timer ERC controls all the oven functions. Everything works except the broiler. (We ruled out the thermostat because the bake function works great).
    Thanks for your assistance.
    Since the bake igniter works fine, doesn't that rule out a low voltage problem to the oven? What is preventing the broiler igniter from getting the power that it needs to open the gas valve?
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    $275 to change an igniter? Holly @%*&# ! Bat Man. Did he test to see how many amps the igniter was using? How about your line voltage? If you have low voltage (say below 115) you'll have trouble getting enough amperage draw to open up the safety valve. You still may have a poor igniter (even the new one). Was the replacement igniter the same syle as the original? (Both either having a rectangular metal or both round metal sheild over the part that actually glows) (Line voltage can vary from day to day and time of day) Better get a firm quote on what the cost will be to repair. Not sure what "control unit" he was refering to. A safety valve, maybe, but an electronic part, NO. I'd consider finding another repair person.
  • 1,543 Answers
Jumptrout51 is correct with the the round ignitor. Using a clamp on digital ampmeter, you should see the amperage use go from zero to at least 2.5 amps after you turn on the broil, then gas valve should open. (the flat ignitors actually require at least a 3.2 amp minimum) Very unlikely the electronic control has anything to do with your problem. Low voltage is not real likely if the oven ignitor is working. Most likely you have a bad ignitor or a poor electrical connection.
Posted on Sep 25, 2009
  • Kenmore Master
  • 3,361 Answers
Turn off the gas to the range. Place a amp meter on the wire between the ignitor and the broil gas valve. Turn the control to broil. If the amp draw is between 2.5 and 3.0 the gas valve is the problem. This is for round ignitors. If the ignitor is flat,the amp draw should be 2.8 to 3.7.
The control board is the least likely problem.
Posted on Sep 24, 2009
Testimonial: "Thanks much for the suggestion. I will try it tomorrow and hopefully we can broil again. Good job!"
  • steve
    steve Sep 25, 2009
    Corrosion can occur on the gas valve terminals as well as a loose connection. Remove the wires from the Broil gas valve and clean the terminals. Make sure the terminal connectors are tight. If not,either adjust them with pliers or replace the terminals.Check the wires back to their respective sources for defects.(ERC and neutral input.)
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
heatman101
Jun 15, 2011 | Magic Chef 9112 Gas Double Oven
My GE xl44 gas range broiler won't work,
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
GE oven/broiler problem: oven works, broiler does not light. Model JGRPP17WEW4WW
This would also go for the broiler also...
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 24, 2010 | GE JGBS23 Gas Kitchen Range
Stove gas, mdl # mgr5880bds lower ignitor and upper both glow bright orange. upper broiler works and lights. lower oven will not light
Just because it glows that does not mean it is not bad...
heatman101
Sep 05, 2010 | Maytag MGR5880BDS Gas Kitchen Range
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Gas oven won't light
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=53999&thid=358497
Gas oven won't light (by 2 users)
Posted by MBeird on Jan 18, 2008
Can hear the clicking of the auto starter when starting the oven, but it stops after 5 seconds and then the oven simply fills with gas. Broiler still works fine as do the stove top burners. Any thoughts?
Good question? You may have a plugged up burner and or the pipes or jets may not be adjusted correctly and it could be your igniter on the gas range because it is not igniting the spark to create the flame. You may want to have it check out with an authorized service repair tech to make sure it is safe and will function well. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Jan 18, 2008 | Whirlpool SF367 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
987 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
