What does HC stand for on the oasis washer?
According to the Whirlpool "Cabrio" washer installation and maintenance manual, (Cabrio is the Sears Oasis) the HC code will come up when.
“HC” (Cold and Hot hoses switched)
This code will appear at the end of the wash
cycle to indicate that the cold and hot water
inlet hoses are switched. If an error code
does not appear, but you are experiencing
poor washing performance, check to see
whether the inlet hoses are reversed. See
“Connect the Inlet Hoses.”
If you are getting the "HC" code and the hoses are hooked up correctly, the washer needs to be reset. 90% of the time unplugging the washer for 5 minutes or so will fix the problem. If not, call a service guy because the electronic control board has other issues.
My cabrio washer has just started coming up with the HC. It has been hooked up for a year and we have not changed the hoses. It just started coming up with HC yesterday. WHY?
SOURCE: kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
