Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
I have a 10 year old Poulan Rider with 14.5 HP 42 in cut. I had 1 of the 2 wires held in a wire holder behind the starter and the grey colored wire had rubbed thru and blew the fuse. I replaced the wire and rerouted it and the motor ran fine for about 5 minutes then died. What is this wire for and can it be spliced? Would this keep it from running?
  • 62 Answers
This wire should be for your charging system. shouldnt have anything to do with running.
Posted on Sep 25, 2009
My poulan pro 17.56 hp, 42", 2014 rider shut down in the middle of a job and won't start back. Engine turns over but just wI'll not start.
check for fuel fault ( blocked fuel filter , no fuel) check for failed spark plug
check for shorted coil wire
Nov 11, 2015 | Poulan Garden
I need to know what the various colored wires connect to since I needed to remove the old amp and install an after market stereo.
Check the speakers connection and that should give you at least 8 of the colors. The ones left then are going to be ground and power and display power. You can figure those out with a meter.
Aug 24, 2015 | 1994 Volvo 940
How to hot wire fuel pump for 97
How to
Hot Wire Your Fuel Pump With a Relay in the Trunk
Terry Littleton - tlnfm@peganet.com
You Will Need
Get 15 ft 10 gauge wire, 3 ft 14 gauge wire, and a Bosch 4 or 5
prong 30 amp relay. Any place that installs car alarms should have a Bosch
relay. Get a heavy 10/12 gauge wire 30 amp fuse holder. They can be found at
auto parts stores and come in the old glass or new plastic spade type fuses.
Make sure it is heavy wire and not like most that use like 14/16 gauge wire. You
will need 2-10 gauge butt connectors, 1-10 to 16 gauge butt connector, 2-10
gauge female spade connectors, 2-14 gauge female spade connectors, 1-10 gauge
and 1-14 gauge ring connector. Soldering gun, wire
protector.
Procedure
  1. Disconnect battery. Put a ring connector on one end of the 10
    gauge fuse wire and attach that to the post at the rear of the alternator. Run
    it over to the front of the drivers side valve cover and attach to a piece of
    ten gauge wire that you will run to the back of the car. I put mine inside the
    car and it was actually easier.
  2. Run it through the hole next to the powermaster where all the
    wires go through the firewall. I routed it over behind the emer brake pedal,
    down behind that kick panel, took off the sill plate and put it inside the
    plastic wire protector (it does come open, just a pain to figure it out). Take
    out back seat and run it from sill up to opening that goes into the trunk. There
    are other wires that do the same thing, just follow them. Bring wire down to the
    hinge support. There is already a hole right there to put a bolt and nut through
    to mount the relay. I had a radioshack relay but it broke so I got a
    Bosch
    and it seems a lot sturdier. Good choice.
  3. Just a word of caution. Follow the wires down to the side of the
    trunk floor. The copper colored wire is the one to attach the trigger wire to.
    It looks like bare copper wire but is actually coated. The coating is so hard, a
    regular scotch lock wouldn\'t make contack on mine, so I cut out a half inch
    section of the insulation and soldered the trigger wire (a small piece of 14
    gauge from the relay prong 86) to there. I wrapped it in tape and put corrugated
    wire guard over it.
  4. The ground wire from the relay (a small piece of 14 gauge from
    prong 85) can go to the bolt hole you use to mount it to the hinge support. Just
    clean off the paint first. Then hook up the 10 gauge wire from the alternator to
    post 30 on the relay. The remaining prong on a 4 prong relay is the "Power Out"
    that will feed the alternator voltage to the pump(s). If you have a 5 prong
    relay the two remaining prongs should be labeled 87 and 87a. One is the "Power
    Out" when relay is energized, the other supplies power when the relay is not
    energized. Use a test light to determine.
  5. Run the remaining heavy gauge wire from the "Power Out" prong
    (when energized) from the relay through the rear of the trunk to the fuel pump.
    Notice the plastic cover over the BIG rubber grommet that takes all those other
    wires from the trunk out under the back of the car? Forget about getting your
    new ten gauge wire through there. Just drill a hole big enough to run the wire
    through covered with some corrugated protector. I put mine right next to the
    rubber plug. Then run the ten gauge wire to the pump.
  6. The 3 wires going to the sender/pump are Black-Ground,
    Pink-Fuel Level Sender, and Brown/White Stripe-Fuel Pump motor. Cut the
    Brown/White stripe wire after the connector on the fuel pump side and attach the
    new ten gauge wire. Leave enough to reconnect stock later if desired. Put a butt
    connector on the old cut wire so it doesn\'t short on anything. I wire tied stuff
    up neat and used wire protector. If you have an external pump, you can run
    another piece of 10 gauge to it for power from where it splices into the
    original pump wire.
  7. Now the wire coming through the firewall goes over behind the
    drivers valve cover and along the back edge of it under the EGR tubing in wire
    protector and splices into the other fuse wire from the
    alternator.
  8. When you turn on the ignition, you should hear the fuel pump
    prime. The only problem I had was in the connection of the trigger wire to that
    copper colored wire in the trunk like I mentioned above.
Hope this isn\'t confusing. I did it this way to keep things neat
in the engine compartment.
Jun 26, 2013 | Cars & Trucks
I have a Poulan 18 HP 42" deck; battery would not charge so replaced it with new. Now starter gear will not engage with teeth on flywheel, sits just below engagement level and just spins. Suggestion
Most starters will have a bendix shaft, once the motor starts to rotate the gear follows the bendix thread up into the fly wheel ring gear, so there is either not enough charge in the battary, or the bendix on the starter motor is bad, or the gear itself is bad, or the battary is wired up the wrong way.
Feb 10, 2013 | Poulan 42 In Deck 165 HP 6 Speed Manual...
Have and older style Poulan rider mower with a 14.5 hp and 42 inch cut. Replaced Battery, starter selenoid, and ignition switch. Now the 30 amp fuse keeps blowing, how come?
disconnect the starter and turn the ignition to see if the fuse blows, if it does not then the starter is grounded, but more then likely there is a stripped/bare wire grounding out somewhere. Hope this helped Tim
Jun 05, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Starter energizes, won't turn engine.
your battery is in a weak state also the solenoid is shorting out replace the solenoid
Jun 06, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
14 hp dynamark tractor that won't start
Have you checked the inline fuse?. Also you could unplug the ignition switch and clean the terminals, particuarly the one with red wire in it. That the one that has constant power to it and tends to corrode over time. Hope that helps.
May 23, 2009 | Garden
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
190 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
