Question about Kodak EASYSHARE 5100 All-In-One Printer
I try to print a letter on basic settings and the Printer will not print. An Error screen pops up stating . "the print job cannot be completed - To use the advanced dot placemment mode, select a bordered paper size and load the paper tray with Kodak gloss paper and run the print job again." I have tried adjusting the settings to no avail. Liam Blake
    Sergeant:
  • 151 Answers
Basically the problem is caused by the printer spooler which is a printer system file that was installed on windows XP
For this problem kindly try doing the ff:
* click START then select RUN
* Type net stop spooler
* Type net start spooler
* Then try printing
* if problem still persist call 1800 421 6699
Hope this will help
Thanks
Byron
Posted on Sep 24, 2009
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
Printer blinking red and showing letter E
Error description:
The Attention (red) light is blinking. There are six possible causes that will display the Attention light pattern:
-Paper out
-Door open
-Print cartridge missing
-Paper jam
-Paper sensor jammed
-Duplexer error
Solution :
After the cause of the problem has been addressed, pressing GO will cause the printer to attempt to recover from the cause of the error. If the printer is unsuccessful, it will continue to display the Attention message until the cause is remedied.
Pressing JOB CANCEL will cancel the print job and the printer will return to the Ready state (Ready light on) unless there is a paper jam still in the printer or the print cartridge is not in the printer.
For more details visit the link below :
Resolve Printer issue
Jun 09, 2011 | HP DeskJet F380 All-In-One Printer
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Apr 08, 2009 | Konica Minolta DiALTA Di200 Copier
Print jobs stick in prnt queue
A lot of users have no idea how to change the MS Office default from US to UK .. so they have US spellings and US paper sizes (known as 'Letter' sized) .. and (of course) any Document that started life in USA keeps it's size until some-one changes it ... since Letter size is almost the same as A4 no-one cares UNTIL they come to print it ...
I'm sure you can guess the rest :-)
Yes, the Printer is looking in it's feed tray for Letter sized paper .. yes, Letter doc's will print just fine on A4 and most printers have a setting somewhere that lets it use A4 when asked for Letter (often called "automatic A4<>Letter convert" or some such)
NB. when time permits, perhaps the unfortunate users can have their MS Office apps. set to UK mode :-)
Mar 17, 2009 | Dell Office Equipment & Supplies
L6 error keeps popping up
That is a laser error. The motor that drives the mirrors is most likely oing bad, The laser unit will have to be replaced.
Jan 30, 2009 | Xerox WorkCentre XD105F Laser Printer
Flashing red lights and letter E on my hp printer
basically for this printer I have found that just restarting your computer will solve almost anything. make sure there is no paper left jammed in the printer and restart. sometimes you have to delete the print job in the printer que. there should be a printer icon down my your clock, right click, open active printers, and delete your file. restart your computer and try again
Sep 18, 2008 | HP DeskJet F380 All-In-One Printer
Hp laserjet 4250
This happens when the printer is printing duplex job. i.e. trying to print the other side of the page.
However check the functionality of the printer by performing Paper path test.
This would help us to know whether the printer as a stand alone ... is fine or not.
From the control panel of the printer, scroll to Diagnostic > paper path test.
Select the following in sequence.
Source: All trays
Copies: 10
Duplex: ON
Print Test Page
Check if you get the same error.
If yes, upgrade teh firmware of the printer.
Let me know the end result. We still have more depending on the above test.
- Nikhil
Sep 05, 2008 | HP LaserJet 4250dtn Printer
Dell 3000cn laser printer
This is usually related to the way the tray or trays are configured on the printer or the way the program from which your printing from is configured. If you are using ms office, as an example, if the instructions to the printer from the software (ms office) say to print this document to the Multi Purpose Feeder tray (MPF) using plain paper and there is no plain paper in the MPF, you will get this error. Conversersly, if the printer's MPF is configured to print only legal size paper, and the software you are using is sending a print job to the printer telling it to use letter in the MPF, you will get this error. Basically, the printer settings and the settings from the software must match in order for this error to not occur. The settings for the printer can be changed usinig the operators panel of the printer. Directions for this should be available in the users manual or from support.dell.com. The setings for the software shold be in the print properties/preferences of the software being used.
May 19, 2008 | Dell 3000cn Laser Printer
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
113 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
