Check the drum rollers, they are normally the cause for squeeks and squalls..Use some good grade of machine oil like 3 in One oil to lube the shaft fo the rollers. That should solve the noise problem
How do you replace the glides/slides? I have a Maytag dryer that's
squeaking, took off front and it's clear it's the glides. Found where
to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
