Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Starts ,but if you pull out PTO are try to let out clutch it dies
2004 Craftsman 25 Hp Garden tractor 48" Mower Mod- 917.276013 I have checked PTO sw., clutch sw and Ign sw all check good. I have checked wiring and it seems OK.. The wiring diagram that came with this mower is not exactly right but I have a good idea of how it gos and I have checked the seat sw. its ok. I known somethings wrong but I just can't seem to find it. I have tryed unplugging regulator and cab. fuel shutoff to see if its was shorting it down . I have unplugged the ele.clutch assembly and its OK .I'm at the end of my knowledge any help would be appreciated
  • 8 more comments
  • longone511 Sep 25, 2009
    When you engage the PTO it dies are when you let out on the clutch same thing. It will start and idol but that's it. Its not the seat SW
    Yes, the PTO SW. Its not the seat SW
    I cannot found it on my model I an assuming it was not put on this model It shows up in the diagram but I have look ever were and unable to found it. If you know were to locate let me know
    Yes
    I found the trouble. It was the clutch SW It was intermittent I took the big ground off the frame and taped it up and then I took the ground side of the electric clutch and jump it to the negative side of the battery and it worked . The only thing is you don't have any safety features which is alright with me. Thanks for ever ones help Longone 511
  • Chuck
    Chuck May 11, 2010
    I am not sure where they may have put it but try following the green wire from your seat switch. The way I read the wiring diagram, it should go directly to the relay so it could be under the seat platform, inside the frame and well hidden or they could have put it up under the dash where it would be out of harms way somewhat.
  • Chuck
    Chuck May 11, 2010
    Have you checked the operator presence relay? It should be a small black plastic box with 5 terminals on it
  • newbla May 11, 2010
    DOES THE ENGINE DIE WHEN YOU PULL OUT THE SWITCH
  • Chuck
    Chuck May 11, 2010
    Please clarify your problem: >>I known somethings wrong<< Just doesn't give much to go on
  • 62 Answers
SEAT SWITCH
Posted on Sep 25, 2009
  • newbla Sep 25, 2009
    make sure you don,t have a belt problem, or binding problem anywhere
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
Where is the PTO switch?
The switch is on the dash bezel, the electric clutch is on the deck. Some clutches can be adjusted but I need the model number of your mower first.
Jul 06, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a husqvarna riding mower.. when i engage pto it kills the mower.. i direct wired the pto to the battery and it kicks on and off while mowing, mower runs fine when the pto is off please help
If you wired the pto directly to the battery and still kicks off and on, you have a bad pto clutch. They can be expensive but they are fairly easy to replace. Hope this helped.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 07, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
CRAFTSMAN 26 HP 48'' DLT2000 MOWER ELECTIC PTO CLUTCH SEIZED UNPLUGGED BUT BLADES CONTINUE TO TURN. CAN IT BE REPAIR OR MUST IT BE REPLACED?
I would say replaced to ensure correct opperation.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Mower
Most mowers have a safety interlock to prevent starting when the PTO is engaged so it sounds normal.
Jun 02, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Have a Craftsman 26 hp, 48" mower...mower starts runs but when I try to engage the blades nothing happens. Checked all the belts, ck for blockage but nothing...what would the next step be?? Tks
When you say nothing happens...is the PTO engaging? You said that you already checked the belts...if none of these are off...you maybe looking at a new PTO clutch.www.nnyparts.com
May 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
220 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
