Question about Onkyo TX-SR604 Receiver
No sound I just set up my new Onkyo TX-SR605 and Onkyo speakers.  I've checked the wiring several times.  Connections look good, correct polarity.  I get absolutely no sound from any of the 7 speakers.  No buzz, hum, or anything else that might indicate that they are connected.  Am I missing something.  Thank you for any help.
Onkyo is a piece of shit! I had the same f'n problem....
Junk...............
Posted on Jan 09, 2008
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
Onkyo tx-SR605 - how do I use as a processor and
IF and only if, your receiver has connections labeled as "pre-out" can it be connected to an external amplifier.
If it does, then you connect from the left and right channels from the receiver, to the left and right channel on the amplifier.
Jan 02, 2010 | Onkyo TX-SR605 Receiver
I have an Onkyo TX-605AV receiver that will goturn off andgo into standby mode with loud sounds, when the volume is turned up usually over 60. I hooked the speaker wiresinto the banana clips for the...
over heating your amp with a problem and its going into the protect mode... better stop before it dies for good...$$$ to fix....speakers mismatch or wrong ohm rating for starters bad speaker, bad xover...
Dec 05, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605. Low or no sound output
Does any good sound come through headphones, if you plug any in?
Apr 24, 2017 | Onkyo TX-SR605 Receiver
VERY LOW VOLUME FROM SORROUND SPEEKERs
some surround sounds do not put out loud sounds except from the front speakers only. Try using different inputs to see if it makes a difference.
Jun 17, 2009 | Onkyo TX-SR605 Receiver
Speaker Calibration error with Onkyo TX-SR607 using Audyssy 2EQ
The only thing I can think of is that the microphone that detects speaker signals is in a position that blocks the sound from that speaker. When it's testing there should be no noise from anything or anyone.
Jun 09, 2017 | Onkyo TX-SR605 Receiver
Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Aug 28, 2008 | Onkyo TX-SR605 Receiver
Audio problems - Onkyo TX-SR605
Same problem. Does the internal Cooling fan turn on?
Mar 21, 2008 | Onkyo TX-SR605 Receiver
Set-up problem with sound and speakers
I sent this TX-SR605 system to an authorized dealer for repair. It seems like it is a very simply problem - the internal set-up mic jacket closed circuit, so the system think the set-up mic is always plugged in (even when physically unplugged it, the system still detect plugged in). And it enters the automatic speaker setup and never quit.
Now I have the receiver back home and tested it. Everything worked O.K. now. It is a pity that this new-bought equipment (just one month) need repair for just a small action of plug in a mic ( I swear I plugged it in very tenderly). It is shame for such a unreliable performance happened on brand name like ONKYO. How can you be confident for an equipment failure in one month.
Dec 25, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 7.1 Auto tune problem
if you only have 5 speaks hook them to surround not surround back. this shoud work
P man
Nov 29, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR604 Receiver Logo
579 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
