Question about Ingersoll Air Tools & Compressors
I have an old model b compressor circa 1956 and the diaphragm in the switch box is leaking where will i get one from please.Many thanks,Gaz
  • 582 Answers
NO SUCH LUCK, I HAD ONE WITH THE DIAPHRAGM AND THE COMPANY WAS NO LONGER IN BUISNESS HAD TO REPLACE WITH A NEWER MODEL AND DO SOME CHANGING AROUND BUT THE COMPRESSOR RUNS GREAT. ALSO THE NEW SWITCH RAN ME AROUND $76.00
Posted on Sep 24, 2009
Need new ON/OFF box
If you take out the old switch it should have a model number on the bottom. Its important that the new switch has the same max pressure and the fittings in the same place. Most switches will fit in most compressors. Ebay has a large sortmiment.
Jan 26, 2014 | Silentaire Technology Super Silent 20-A...
Compressor leaks at pressure switch
The diaphragm in the pressure switch is leaking. A new pressure switch is the only way to fix it
Feb 19, 2013 | Senco PC1130 Compressor, 1.5-Horsepower
Bostitch compressor
If air continues to leak from the pressure switch after cycle is indication that the check valve is not sealing or the pressure switch diaphragm has failed. Easy fix. Follow the 1/4 inch airline to the tank and remove the line from the brass valve(check valve). If air is leaking at the brass valve, remove it and attempt to clear debris under valve or replace as needed. If no air is leaking from the checkvalve, then most likely diaphragm is leaking. You could replace the diaprhagm or the whole switch. Generic switch is available thru ebay about 18- $20
Oct 29, 2011 | Air Tools & Compressors
I have an old 5hp 20 gallon horizontal Craftsman air compressor that is well over 20 years old. The on off presure switch died so I replaced it with a Powermate unit of the same on - off pressure...
possibly an installation problem
most control units screw directly into the tank and the pressure is read directly to the diaphragm that controls the switching
check if the bleeder line is supposed to be attached to the control unit at all
unless you have a peculiar set up the compressor line goes to a nonreturn valve into the tank
there is a relief valve in the tank that blows off when dangerous pressures are reached ( around 120 psi)
there is a fitting where the control screws in and that reads tank pressure to control the on/off of the motor
Apr 17, 2017 | Craftsman Air Tools & Compressors
Air leaking from air pressure switch
Most pressure switches use a diaphragm to activate the contacts that may leak, however, air leaking from the unloader after compressor reaches cut-out is result of in-tank check valve. Easy to check. Turn off power to unit and remove 1/4" tubing at the check valve (follow 1/4 tubing from pressure switch to check valve). If leaking remove from tank and clean debris under seat or replace with generic from www.grainger.com Good luck
Sep 28, 2010 | Ingersoll Rand - Rand Type - 30...
BMW 318i 1999 model, air con not working
hi
I had this problem before. There could be several reason.
1-Your air conditionner filter could be soo old and dirty, that you don"t get that good air condition.
2-Your air cond compressor could be giving low pression and so, no cool air.
3- You could be having a leak somewhere and so you're loosing gaz after it's filled.
4- Check also the fuse box. Seee if the AC fuse is not burnt.
thanx and don't hesitate to come back to me
May 05, 2009 | 1997 BMW 318
My porter cable compressor will not automatically stop when it reaches the set psi
There is a fairly simple mechanism that turns the pump off when the pressure reaches a set limit,and turns the pump back on again when the pressure drops below another set point.The motor is controlled by a switch that is actuated in one way,or the other by a diaphragm.The actuator may be disconnected from the switch,the switch may be bad(stuck in the closed position),or the diaphragm may have a hole,or tear in it.You can try removing the switch,and seeing if it will open,and close manually(If not replace the switch).If the switch is good,and the connection between the diaphragm,and switch seem intact you probably have a damaged diaphragm.It could be difficult to detect because of the pressure involved.(You may not be able to tell its leaking by blowing on it). One possible test would be to make a solution of soapy water,and spray,or apply it to the diaphragm parts in some other way,And look for a leak that way(look for growing bubbles)(Be careful with live electrical parts!)
May 02, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Central Pneumatic 94667r 3 hp electric oiled compressor
sounds like your check or reed valve is bad. when the piston pressurizes and pushes air into tank the pressure should not be able to come back into cylinder and thsi is what its doing and then that pressure is now going past rings into oil. look for the valve before the tank. a check valve.
Apr 23, 2009 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Leaking Pressure Switch
Leaks at the pressure switch are usually associated with the unloader valve due to leaking checkvalve at the tank. To determine the faulty part requires a couple of tests. Run compressor till it shuts off and is full of air then unplug the unit. Spray soapy water or (windex) around the base of the pressure switch to find where air is leaking from. There is a rubber diaphragm incorporated into the base of the pressure switch that may develop leaks. If the base is leaking check for loose parts or screws. If the air is leaking from a valve that looks like a tire stem, then leak is a result of faulty check valve in tank. Follow the 1/4 tubing that is connected to the pressure switch down to the brass valve at the tank. This brass valve is not holding tank pressure causing leak at the pressure switch. Replace as neccessary. The pressure switch is expensive. Do not replace unless you have looked at checkvalve. A universal pressue switch can be and should be used to same money. The check valve need not be replaced with exact replacement. Universal parts are available at www.grainger.com . Just match tubing and thread sizes and pressure range for the switch. Good Luck on your project and email if you have more questions. Please wait for the soapy water or windex to dry before you plug in the unit.
Feb 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
47 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
