Question about LG RZ-20LA70 20 in. LCD Television
Allways in standby
Hi there.
the standby led light is allways on. nothing happens when i press the buttons. there is a small circuit board just for the power, volume and channels button, i dont know but shouldnt this be recieving some voltage? ive checked but nothing.
tanks
  • floppyman Dec 16, 2007
    yes i tryed , it does go off, when i plug it again the light comes back on and back to the start.
    i bought this tv with a broken lcd... ive changed the lcd but now this. i dont have the remote controll for it.
    like i sayed before the light is red (standby) and when i press the AVTV button to turn it on, nothing. and eaven when i press the power button (to turn it of completly) nothing happens again. ive checked the small circuit board for thosse buttons and there isnt any voltage going to it.
  • floppyman Dec 17, 2007
    ok.. thats exactly why im here... i changed the lcd my self and i know some electrics... i dont know if the tv was working before becouse i bought it with the lcd gone.
    is there any one that can help me with this?
    Scholar:
  • 102 Answers
Did you try unplugging your TV wait for seconds and plug it back in. Does it go off?
Thanks
Posted on Dec 16, 2007
  • Adnan Manzoor Dec 16, 2007
    floppyman:
    The circuite board for the swith panel must have current to enable them to work. Looks like you have to take your TV to the certified technician (or company) who fixed the lcd for you. Let them know that this problem came on after the lcd was fixed. Its a hardware issue which can only be resolved after physical input.
    Good Luck!
Dear Jimmy, I have a 50PA4500-UM from LG. It has sound but black screen.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 20, 2017 | Televison & Video
PRESS POWER ON RED LIGHT ON POWER BUTTON COMES ON AND ALSO NORMAL BUTTON FLASES THEN NOTHING HAPPENS THEN A CD CODE FLASHES NOTHING HAPPENS
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 26, 2017 | Televison & Video
My 16" led lcd dvd combo TVs does not turn on. The standby light indication is on but when I push the standby button on the TVs unit nothing happens. As I have lost the controller and un able to switc
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 05, 2015 | Televison & Video
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Mar 26, 2014 | Televison & Video
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
No power
Yes, the power is working as well as the processor seems to start up the circuit but it ends up with a protect shut down. So it is possible there is some error due to a fault or short within the main board and this might require fault finding using the circuit manual.Remove power remove the main board and look for shorted main capacitors, shorted drivers or open circuit of fusible resistors which can help with fault finding.
Dec 12, 2011 | Epson EMP-TW10H Multimedia Projector
SAMSUNG TXH1970... The standby light is on, but when I press the power button nothing happens.
Hello
There is some short circuit in the secondary side of the switched mode power supply section inside the circuit board. Now only the 5VDC is correct, as you see the standby light ON. The short is likely to the horizontal output transtor. Replace it first and see whether it helps you. If not line out put transformer is faulty, and should be replaced with same type and number..If any internal short occurs, the power supply protection system will activate, and shut down all other secondary power supply rails, as a protection to prevent further damage to more components, This is happening in your TV now. OK
May 22, 2011 | Samsung TXH1970 TV
Emerson AV101 System
I'm in the same boat... happened once before, then came back to life. Now it's back to a red standby light and no ejecting tray
Mar 04, 2007 | Emerson AV101 System
LG RZ-20LA70 20 in. LCD Television Logo
116 people viewed this question
