Question about Fisher and Paykel GWL11 Top Load Washer
Doesn't seem to want to spin, drum turns a little
When you turn machine on it doesn't seem to want to spin, drum turns a little when first turned on, some water comes out, starts and stops, then just starts beeping and nothing happens.
  • 6,784 Answers
HI. the first action is to test the lid switch. The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed. Aside from electrical problems, the switch may suffer from a mechanical problem. The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position. Your design may differ, so inspect it for proper operation before proceeding to the electrical testing.There are two primary types of lid switches. One type on which you can directly test the terminals on the switch and another style where you have to test it at the wiring harness. In either case the method for testing the switch is the same. If a wiring harness is used, separate the two pieces of the harness and test the side of the harness that connects to the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multimeter. If the fuse is bad, replace it with one of the same rating.
If the lid switch is operational, i would move on to the next possible issue. This will be the motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission . A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
***(I would suggest to check the following while you are in the area for faults as well(((Clutch,motor,motor board,transmission))). inspect these areas thoroughly)
Ok, if all the above checks out ok and, there are no signs of damage to any of the above parts stated, this will confirm a timer control module malfunction. replace the control device(timer or control board) asap, if possible.
Posted on Sep 24, 2009
Whirlpool washer 8525079 has 2 problems. First, with heavier loads the auger barely moves. Probably the dogs from what I'm reading. Second, during spin cycle, it sometimes will spin and sometimes won't....
I found replacement agitator dogs at a local appliance parts store. Pretty simple fix for the worn-out dogs. The parts came with installation instructions.
If the drum won't turn by hand, then it's probably a stuck drum brake just above the transmission. You can fix it by putting a little dab of silicone grease on the inner surface of the cup-shaped brake drum, and then working the drum back and forth until the grease comes in contact with the brake shoes. You can do this from the bottom of the machine without removing any panel - just tip it over on its back.
Oct 25, 2013 | Whirlpool Washing Machines
Hi, I just purchased an older style washer dryer combo. When loaded (with as little as two towels) it doesn't agitate or spin. Belt is fine. Drum starts to turn but can't make it up the hill. Any sugg
Your motor may be having trouble starting due to a bad capacitor or start winding in the motor. Ideally you want to use a multimeter to test resistance of the start winding.
Jul 31, 2013 | Washing Machines
Mtd4 mistral
Underneath where the motor is,, there is a locking mechanism, which is operated by a cable connected too the lid, check cable hasn't snapped or come off,, it's adjustable also,, may just need adjusting
Jun 17, 2013 | Creda S202pw Debonair Spin Dryer Drier 9lb...
Drum doesn't turn fully
sparks from underneath and you try to wash clothes? lol ....
I think is the belt loose of the washing machine. you need to open the back and I bet you'll see the problem.Hope it all go well...:)
Jul 27, 2012 | Washing Machines
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
Maytag mav7504eww- original problem - smoke with electrical smell and machine shut down due to motor overheating- opened machine - noticed white powder everywhere ( snubber) so replaced snubber and belt-...
Cooked electric motors rarely perform the same as uncooked.
My guess is field windings have shorted so not providing enough output. I'd be replacing the motor.
Apr 16, 2017 | Washing Machines
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Fisher and Paykel GWL11 Top Load Washer Logo
307 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
