My printer keeps coughing up pages with weird numerals at the top. I have tried using notepad, tried to delete the queque...two pages won't delete. Help
    Brigadier General:
  • 4,090 Answers
Turning off the printer and the PC should clear the queue. The printer is out of memory when something like that occurs.
Posted on Sep 24, 2009
Document stuck in queqeu cannot print tried changing line tried on off. help c4280
If you are using it witha computer you need to go to the printer section and delete all the documents from the print queue.
Mar 15, 2015 | HP Photosmart C4280 All-in-One InkJet...
CANON PRINTER MP560 WONT PRINT IN BLACK
This is seems to be weird issue you are facing with the printer. I would like to know what is the application you are trying to print from ? Is it Microsoft word etc ? Try to type something in Notepad and print and check if the black is printed.
If you are able to print from Notepad then probably it there are chances the application you are tying to use is corrupted and might need to uninstall and reinstall
Regards,
Suhail
May 14, 2012 | Canon Office Equipment & Supplies
I"m trying to import a addresses using a csv Excel
The problem occurs, only when the CSV file was edited and saved by MS Excel. The solution: use only Notepad, Excel never!
Feb 18, 2011 | Xerox WorkCentre Pro 123/128 Printer
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I clear the quequ in V510 series? Cleared
Click on the printer icon in te tak bar. Open the printing queu and then delete all the pending tasks. Alternatively, from the control panel, right click on the printer and clear the queue
Dec 02, 2010 | Dell AllinOne Multifunctional (v515w)...
SerialNumberJob appears in the printing queque
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab20
Jul 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Pending on queque cannot be deleted
You might have to turn off the printer and turn it on again. If you cannot cancel print jobs in the queue, then your next step would be to shut down the computer and restart. The last resort would be to delete the printer and reinstall it.
Jun 10, 2009 | HP Deskjet D2360 InkJet Printer
Our Lexmark T610 laser printer
you have the wrong drivers for the printer. You maybe getting weird characters also. When you turn it off it clears the memory buffer (print job). I assume it seft tet OK. Delete and reload drivers
May 11, 2009 | Lexmark Optra T610 Laser Printer
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  3. Press <OK>.
    1. Press <OK>.
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    6. Press <OK>.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
375 people viewed this question
k24674
jasbo
jasbo
