Question about Ricoh Aficio AP3200 Laser Printer
How to print double sided on a ricoh ap3200 with duplex
pagebor
  • 2785 Answers
SOURCE: HP laserjet 5000 series PCL 6 driver
have you tried from the print command dialog box from pc
Posted on Apr 28, 2008
SOURCE: HP Color Laserjet 5550 not printing duplex
Y U
Posted on Oct 07, 2008
  • 11 Answers
SOURCE: Reset Duplex Unit Correctly on Ricoh 2232C
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Posted on Jan 31, 2009
  • 161 Answers
SOURCE: not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Posted on May 06, 2009
santosj27
  • 263 Answers
SOURCE: setting the duplex printing for RICOH Aficio MP
You just need to go to printing preferences and set the tab duplex. (Opens a tab and you chose which one you want.)
If you want to put duplex by default, go to:
Start - printers - click on the right on your mouse - properties - Printer preferences - and Change the duplex. In the end just click on "apply".
Posted on Feb 24, 2011
2 sided booklet option
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jan 20, 2012 | Ricoh Office Equipment & Supplies
How do I read the meter on Ricoh AP3200 printer
The meter is on the configuation page.
Menu > List/Print > configuation page
once printed out it is in the upper right of the page (usually)
Mar 23, 2010 | Ricoh Aficio AP3200 Laser Printer
Replaced a hp 8150 with a ricoh 8200. When
That is the way duplexing works. Both sides of the page are read into memory and then the second page prints followed by the first page after the paper turns around.
Turn you paper stack over so the the 2nd. page prints correctly on the page and the first page should be fine. If it does not, please let me know and we can take some steps to look at the data going to the printer.
Don
Mar 10, 2010 | Ricoh Aficio SP C820DN Laser Printer
How do you print via computer double side print automatically with duplex on a Ricoh 1232C copier printer.? (also know asc Aficio DSC, Gestetner R032C, Infotec)
First you need to enable the duplex option in the accessories tab.
Go to printers, and sellect properties(right click) and accessories.
Feb 25, 2010 | Ricoh Aficio 1232C Color Copier
Cant find the setting for double-sided printing on a Ricoh printer
Go to the start menu from the windows desktop then go to printers and faxes then when you will see the driver for the AP 3200 click the right click while the pointer is on the driver and then click properties from the drop menu, then go to accessories and see do the Duplex unit is selected but first see do you have the duplex unit on your printer you will easy notice by the picture when you will select the duplex unit.If you have the duplex unit on the printer then just select the duplex unit then click apply and then ok and now you can close the window. now when you will want to print duplex when you will click the print button from the word or PDF document go to properties and select that you want to print duplex
Jan 26, 2010 | Ricoh Aficio AP3200 Laser Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Double sided issues
Duplex means 2 sided copying. If you have an odd number of pages, then it will do this if you are sticking them all together (if I understand what you are saying correctly). Either seperate your jobs or stick a blank piece of paper at the end to correct this. Again, I am not sure if I am understanding your situation correctly, but I think that will correct it if its what I think you are saying? Clear as mud, huh?
May 22, 2009 | Ricoh 3310LE Copier
Ricoh aficio ap 3200 "error5"
check the paper tray motors and gears and spring
Apr 07, 2009 | Ricoh Aficio AP3200 Laser Printer
Not printing double sided
check the driver
Apr 01, 2009 | Ricoh Aficio SP C410DN Laser Printer
Double sided is no longer an option with mac os 10.5.4
Go into the advanced settings of the driver and look for the settings that tell the copier what features you have. Make sure the duplex is turned on. Normally I set these up for Windows use and I have one client who uses a Mac and he did show me that the features do exist for the print driver.
Once it is enabled the double sided printer feature should work.
Dec 29, 2008 | Ricoh Aficio 1515 Black and White Copier
Ricoh Aficio AP3200 Laser Printer Logo
363 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
