Insignia tv modle is-tv040919 tv turns on red light is on then shots off in a few seconds no sound no picture
  • 4,889 Answers
Does it make a clicking noise when it turns off? Also what is the status of the front panel LED when it turns off?
Posted on Aug 09, 2010
I need a master reset code for my insignia is-tv040919
You should be able to reset the TV to factory defaults via the onscreen menu system. Also, power-cycling the TV (turn it off and unplug it for several minutes) can serve to reset. Additional troubleshooting steps can be found in the owner's manual.
Mar 14, 2010 | Insignia IS 20" TV040919 TV
Cannot program Insignia IS-TV040919 20" TV on a comcast 3 device remote (red OK button) None of the codes work.(10171,11204,11963,12002)
No problem, This issued will be only resolve with regular TV's, not LCD or PLASMA Tv's. Just press TV botton locate on the top leftside of the remote, right after hold the SETUP button for 3 seconds once the TV botton blink twice go and press 991 then 1 again, right after you have pressed 991 the TV botton will blink twice and when you press 1 will blink twice as well, after those steps keep pressing the channel up botton until your Tv shut off. That will work. Good luck
Jan 07, 2010 | Insignia Televison & Video
Insignia is-tv040919 remote codes
The Insignia is-tv040919 is a Cytron and the code is 11326. But no Comcast multifunction remote contains that code -- so you cannot enter it manually and the 991 search function will not find it. I discovered the make and code by the serendipity of having a cable box with a multifunction remote and several DTAs with the small, black two function remotes. I first installed the Insignia on a DTA and the remote programmed quickly. I just moved that tv to the room with the cable box with the multifunction remote and mayhem ensued. I got an $8 RCA 3 function remote today and it's working great on the Comcast cable box, a DVD player and, drum roll please, our old friend the is-tv040919.
Nov 01, 2008 | Insignia IS 20" TV040919 TV
INSIGNIA is-tv040919
you please let me know which IC is used in that ckt then i will let you know immediately
regards
manahar
Aug 31, 2008 | Insignia IS 20" TV040919 TV
My insignia tv
1) Try P-Lock and pasword "0000"
2) Turn TV off and unplug from wall outlet for 30 seconds
3) Check p. 9 and other relevant sections of your user manual.
4) Call Insignia at 1-877-467-4289
May 26, 2008 | Insignia IS 20" TV040919 TV
TV shutdown, red light blinks Screen never lights up.
At this point, the tv has gone into protection mode. Some components is faulty and to prevent more damages.
Regards
alan
Feb 26, 2008 | Insignia IS 20" TV040919 TV
Tv turns off by itself
Try unplugging the cord for a few seconds and then plug back in. This happens on one of our TVs. Using this procedure takes care of the problem. It is like something needs to be reset.
Dec 16, 2007 | Insignia IS 20" TV040919 TV
Insignia IS-TV040919 color problem
The tv has been dropped or banged around, you can try to get a degaussing coil and fix the colors, if you cant pull them back out than it would need a CRT/Picture tube...in other words the tv would not be worth anything.
Nov 11, 2007 | Insignia IS 20" TV040919 TV
Green Screen
check on crt board green amp transister and associated ckt should be short. or green drive transister,or main jungle ic which drive green signal is sure defective, i had the same problem in rca 32 inch tv for all screen red,replacing chroma ic solved the problem.
Sep 12, 2007 | Insignia IS 20" TV040919 TV
No picture
It sounds Like you Had Horz Failure In your Set,The Squealing you Heard was Probly the Horz Output Transistor,You will Probley have to take it to a Shop
Jul 17, 2007 | Insignia IS 20" TV040919 TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
