Question about Fafco Sungrabber Standard Above Ground Solar Heating System
My fafco solar panel is now a warm water fountain spray system. There are a small number of pinholes. What's the best way to repair this? - Epoxy - Plugs - ?
  • 366 Answers
You can contact fafco or heliocol and get a plug kit. its a rubber plug that once you cut the tube you insert the plug into the tube and then insert an expansion peg behind it to help it stay in place.
Posted on Sep 25, 2009
Had my roof replace so had plumber remove solar panel and reinstall now the water does not circulate and the system just flashes
The two pipes that connected the pump system to the solar heater were probably capped and they should have been connected to cause normal water flow. I hope this helps.
Aug 21, 2011 | Fafco 2 PANEL DELUXE SOLAR HEATING SYSTEM(...
How do I fix a pinhole leak in the water dispenser tubing of a GE refrigerator freezer model TFX25KR TFX22KR?
You can repair those pinhole leak with a solvent used on pvc water tubing.
You can also use a epoxy that are specifically use on marine vehicle.
Put a small amount and apply to those pinhole.
Just be sure before you buy, look for those non-toxic material that is not hazardous to health.
Thanks for asking.
Jul 01, 2011 | Refrigerators
I have 2 inch PVC system for my pump and filter. Fafco inground system has 1.5 inch piping. Where is the best way to reduce 2 inch pipe to 1.5 inch (at the diverting valve or at the panel)? Another...
Honestly, I think you are over thinking both your problems. Reduce to 1.5 inch pipe as close to the ground as possible. It is more work for your pump to push water up a 2" pipe then a 1.5" pipe, but it will do either without any real problem.
As far as mounting your panels, as long as they are above the water level of the pool the water is going to drain out of them just fine. You can slope them slightly, but you don't need to.
Apr 16, 2011 | Fafco Inground Deluxe Solar Heating System...
I have an error code S2. what does that mean?
Did you ever get an answer.
I get the same error code. "S2"
Jan 09, 2011 | Fafco 2 PANEL DELUXE SOLAR HEATING SYSTEM(...
I've a pentair solar control panel for my solar system for my pool. On one sunny and very warm day in California, the water in the pool remained cold after a few hours of circulation. Therefore, I was...
There are many variables to this......
How big is your pool how big is your solar system.
Solar temps don't rise quickly ever, and definitely not when the temp is only 75 outside.
You need 80-90 degrees or more on the roof to see quicker results, if the water temp is currently at 70 and it's 75 degrees outside and 80 on the roof you will barely get any change.
You will also lose the heat at night due to lower temperatures.
Once it's hotter outside and warmer at night you get the gains and keep them.
Hope this helps
Mar 24, 2017 | Fafco Deluxe Solar Panel Heating System 1...
How to setup a diverter valve for above ground
If you want all your water going thru the solar heater before re-entering the pool, you'll need to plumb the end of your filter to the solar heater, then the water exiting from the solar heater would go where the filter hose did go back into the pool. Hope this helps.
May 25, 2010 | Fafco Deluxe Solar Panel Heating System 1...
Support of 4x20 panel
The picture obscures the fact it is mounted on plywood panels which are leaned against the pool.
The manufacturer does not offer any sort of support for it. You'll need to install it however it bests fits your pool/yard.
Jun 02, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Fafco Solar Panel system - how to bypass sensor?
I would, put a quarter turn ball valve in the sensors place.
Apr 14, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Swimming pool solar heater panels freeze problem
Depending on the manufacturer, your solar panels may be replaced under warranty. Our installer says that once the panels begin leaking, they tend to deteriorate fairly rapidly. For example, three leaks the first year, 7 leaks the second year, 30 leaks the third year.
Many solar panels are warrantied against freezing, but that is not likely to be the future of the warranties, because they inevitably DO freeze and leak.
If there are just a few leaks, it is easier to fix them - a Fafco Solar panel repair kit can usually be bought from your installer for about $25.00.
If you turned the pump on to manual to circulate the water through the panels, that should prevent a freeze - but will cost you the electrical cost to run the pump.
Our experience has been that it is better NOT to drain the panels - we had many fewer leaks the years we have not drained the panels, despite occasional hard freezes in our part of California.
In addition, your rooftop installation should help radiate some heat up to the panels to keep them from freezing.
Check your warranty and get the panels replaced if there are more than a few leaks.
Mar 21, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Freeze Protection for Sola Panels
Running water through them all night would prevent them from freezing, but it wouldnt help the cause, as it would be cooling the water and using electricity. When I installed solar panels I used isolation valves, and simple drains that were to be opened to allow the water to drain out. Glycol does not enhance the heat transfer, as plain water is best - it is only for antifreeze. And you dont want anitfreeze in your pool.....
Mar 20, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Fafco Sungrabber Standard Above Ground Solar Heating System  Logo
569 people viewed this question
Top Fafco Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Fafco Pool and Spa Expert? Answer questions, earn points and help others
