Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No picture after replacing lamp - Mitsubishi WD-52525 52" Rear Projection HDTV
  • Mitsubishi Master
  • 5,138 Answers
Bad Ballast Board ,it is what turns Lamp on Call Encompass for Part 1-800-638-3328
Posted on Sep 24, 2009
How do I know if my Sony 50e3000 lamp needs replace
Most common indicators are:picture may be dimmer or flickering, or no picture with lamp lite error code flashing, or message on screen indicating lamp needs replaced, lamp 1 year old or older.
Mar 05, 2015 | Sony Televison & Video
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
I have no picture. I have sound, but you can not increase or decrease the volume. I can change channel theu the cable box but still no picture. The lamp indicator light is not on. Sony...
Hi:
Just because your lamp indicator is not on does not mean that its not time to replace the lamp. This light only comes on if the lamp shatters in its housing, but if the lamp is worn or faulty it will not light the lamp light just no picture symptoms replace your lamp first.
Mar 27, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
I've replaced the bulb in my tv and the red lamp light is staying on with no picture or sound. What can i do to get my picture back?
Did you put back lamp cover after lamp replacement?
Make sure lamp cover has been fixed in its place securely after lamp replacement.
Aug 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
Thanks.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDF E42A10 picture loses quality.
It sounds Lamp is weak and causing darker picture.
How old is this TV and did you replaced Lamp recently?
If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual.
Thanks.
Nov 05, 2009 | Sony KDF-E42A10 42 in. LCD Television
Intermittant lamp cycling
could be lamp or lamp driver the only way to tell is to replac on at a time.
Aug 11, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
