Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint cleared filter but f11 shows what can i do to solve this
  • 6,784 Answers
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.(F-11)
Possible Causes / Procedure
1. Unplug washer or disconnect power. 2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU). 3. Check the drive system for any worn or failed components. 4. Plug in washer or reconnect power. 5. Verify CCU operation by running a Diagnostic test or any cycle. 6. Check the MCU by looking for operations of the drive motor. 7. Check the drive motor for powered rotations. 8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Replace failed component.
Posted on Sep 24, 2009
Testimonial: "many thanks nice to know not everyone is out to rob someone. cheers"
F11 error on Aquarius wmf 720
There is a syphon tube with a cover dome like a thimble. Lift it off, clean it and clear the syphon tube. Refit the cover.
Nov 18, 2012 | Hotpoint Washing Machines
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi I have a hotpoint ultima it is showing f11 could you tell me what it means Thanks
F11 - No pump connection.The drain pump is either blocked or drain pump is loose or drain pump hoses are loose .Or the drain pump connections are faulty. The error f-11 is related to drain pump and its connections,. ----------- You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
How do i drain and clear filter as machine wont spin on hotpoint wma 76?
Remove lower rear cover from washer.
Remove large black hose onto bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
This should helpo solve your problem.
Nov 29, 2009 | Hotpoint WMM65 Front Load Washer
My Hotpoint Ultima super silent is occasionally showing the warning sign F11. Can you tell me what this sign means?
F11 means the pump cannot be activated.You may have a loose conection or faulty pump. For Hotpoint error codes go to http://www.selfix-uk.co.uk
Jul 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt741 f11 what does this mean
Hotpoint Error Codes.
Hotpoint washing machines are among the most common found in the Uk and like any mechanical device they will occasionally breakdown or develop a fault and need repairs.
Being a very popular make means that most parts supplier will keep there parts in stock and because so many suppliers keep Hotpoint parts stock this also drives competition hence driving down the price of parts if you should ever need them
One problem many people including some engineers face when faced with a faulty Hotpoint washer is knowing what the error code mean, so here are a list of error codes and there meanings for Hotpoint washing machines
These error codes can some times have a E in front of the number and not a F as shown here, but the meaning of the code is still the same
# F11 - This means there is No hot fill.The ambient temperature is probably below freezing perhaps due to the plumbing becoming frozen. Also verify that the taps are on or if the drain hoses are kinked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 26, 2008 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
141 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
