Question about Samsung WF337AA Front Load Washer
Softner Compartment won't drain
I have noticed for at least two months that when I start a new load of laundry there is still some water left in where the softner goes. Now, I put softner in the compartment and it will not drain into the laundry. I have done at least 3 more loads of laundry and the same softner is in the compartment.
  • 1,531 Answers
This may be a faulty valve that allows the water to fill the softner compartment.to check the draining capability remove the drawer and take it to a sink make sure it remains level you you sink tap or a cp of water and fill the compartment almost to the top and it should start draining once it starts to drain stop putting water in and watch it. it should finish draining by itself there will be some water left in it but only a small amount. if it does not drain clean it out.
Posted on Sep 26, 2009
Where does the laundry powder go on the left or right compartment?
I am going to presume u have a front loading machine in your home,, put the powder in the left hand compartment, as the right is for use of a fabric softner if u wish to do so :)
Apr 17, 2011 | Bosch Washing Machines
The fabric softner compartment of my whirlpool duet washer is completely full of water
Mine is doing the same. For over 2 months now I've been adding fabric softner to the detergent compartment but I broke down and called a repairman to come tomorrow... at a ridiculous repair rate. My washer is less than 3 years old and this will be the 3rd major problem that needed to be fixed. I've seen a lot of people post the same problem - some say all 3 compartments won't drain.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The fabric softner cup will not drain
I don't know the solution to this either. Both my Whirlpool, front load washers: old one (15years old) and new one (2 months), the softner itself is always drained into the wash and residual water is there at the end of each wash.
Dec 20, 2010 | Samsung WF337AAL Front Load Washer
Softner stopped draining out of the compartment during the rinse cycle. When I open the compartment after cycle stops, there is still softner in the cmopartment
try pouring really warm water in the compartment or using small soft toothbrush type brush to clean out the build up of softener. You might try thinning your softener in the future with water if it is very thick. this works for me
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Water was overflowing over the top and flooding the laundry room
If it was left in the reset position then it could absolutely pushed the diaphragm in the air switch to a point that the contactor couldn't reach it. Set it on a large load, let it fill and watch it. If it starts to overflow, pull the plug out, if it continues filling, you need a new water valve on the washing machine and if it stops then you need a new level switch
Jun 16, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Detergent reservoir won't drain after cycle finished. Water stays in it.
hopefully your using the HE type detergent an fabric softner, an not using but a teaspoon full each. the machine will detect if there is any product left in depenser. an too there will be some water left to keep lines an seals mosit. to keep from drying out so thats normal.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water left in bleach and fabric softner after running load
You must take out the compartment and empty it out before adding any bleach the next time, there is a type of button way in the back that you press down on pull out the entire door and empty the water for the next washing. You must press down very hard the entire door does come out check out your book for instructions it is way in the back on the left hand side. This happens to mine once in a while not all the time.
May 05, 2009 | LG WM1812C Front Load Washer
Detergent dispenser is filled with water after wash is completed.
The water is left there because the syphon action is not working in the dispenser, what you need to do is to remove the dispenser drawer completely and thoroughly clean the conditioner compartment, poking any holes or tube, particularly the syphon tube with a piece of flexible wire or similar to ensure it is completely unblocked.
. to test, fill the conditioner compartment with water, and it should slowly empty itself, if it does not, then it is still blocked.
Plz rate this solution.Thanks.
Dec 27, 2008 | Bosch Washing Machines
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Samsung WF337AA Front Load Washer Logo
141 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
