Question about Ricoh Aficio 450 Copier
Proplem in aficio 450
In this modeles i have abig problm the copier write erorre sc 322 i know this problem is unite laser .
but i test it
1- the polegon motor is good
2- the LD unit is good
3- the secothenaion board is good
i think this problem in mirrore
i hope if you can help me
  • 2 more comments
  • Anonymous Jan 07, 2008
    1. the polegon motor is good
    2. the LD unit is good
    3. the secothenaion board is good
    problem face on mirror
  • raghu ram Jan 07, 2008
    please answer the above questions to send my email address onraghram3300@yahoo.co.in
  • Anonymous Mar 28, 2014
    stock in registration
Thank you for your import
my name is waiel from egypt
my email / waielrezk@yahoo.com & this is my msn massenger
i hope to conncted
thank you
Posted on Jan 02, 2008
  • 417 Answers
322 C 1st laser synchronization error
• The 1st laser synchronization signal
cannot be detected by the main scan
synchronization detector board even
if the laser diodes are activated.
• Poor cable connection between the
laser synchronization detector board
and the LD unit.
• Laser synchronization detector board
out of position and angle of reflection
not correct
defective
• LD unit defective
Above is a detailed description of your problem if the copier has had a knock there maybe a mirror out of position. remove the laser unit and open. check that the mirrors are in there correct places.
Once you have done this enter service mode by pressing the yellow clear all button type using the numeric keys 1 0 7 the hold the pink stop button down unit the screen changes. press the Copy SP mode button on the screen then turn the machine off using the switch on the left hand side wait about 5 - 10 seconds and switch on then try the copier. If the problem comes up again you will most likely have to replace the LSU (Laser Scanner Unit)
(Important DO NOT ADJUST ANY OTHER SETTINGS IN COPY SP MODE AS YOU MAY DAMAGE THE MACHINE)
Hope this is some help please rate me
J
Posted on Dec 30, 2007
Sc 322 for RICOH AFICIO 2045
That is a LASER error code.
It can be just toner dust because that error is a bad communication between the laser synchronization detector board and the LD unit.
Sometimes the dust of toner goes to the laser and causes this error.
Try to clean the laser unit. Maybe that work
Feb 24, 2011 | Ricoh Aficio 450 Copier
Codigo sc-322-000 copier ricoh aficio 450
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
Hope that helps!
Oct 22, 2010 | Ricoh Aficio 450 Copier
Open cover on aficio 2045 copier problem
this proplem has many solutions 1- may laser cable did't reach correctly to laser unit 2- stike of door is shortly or broken
Oct 12, 2010 | Ricoh Aficio 450 Copier
Ricoh aficio 2035 sc 322 (unidad de lazer en buenas condiciones) ?que mas puede ser ¿
sc 322 is a laser unit problem. find a ricoh technician and clean the laser unit or replace it. this laser problem is hard to solve usually.
Sep 28, 2010 | Ricoh Aficio 450 Copier
SC 322
sc 322 how to solve this error
Jun 16, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio AP 2600 laser printer there is a code SC-322
On most Ricoh models, SC-322 is a problem with the laser unit. If you have a service contract, have your technician take a look at the printer. Otherwise, you can either have a local Ricoh tech give you a repair estimate or buy a new printer.
On rare occasions you can turn the printer off and turn it back on and the code will be cleared, but most of the time this is a serious error that requires a service technician.
Apr 28, 2010 | Ricoh Aficio AP2600 Laser Printer
Sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Oct 25, 2008 | Ricoh Aficio 1035 Copier
Aficio 450
SC 322 is a laser diode problem. It will require service.
Mar 27, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
176 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
