Question about Ovens
4 conductor wiring for a range, red goes to red, black to black, does the white and yellow go to the middle together?
    President:
  • Ovens Master
  • 1,922 Answers
White is the neutral line and goes to the "N" terminal, the other is YELLOW??? not GREEN,which would be the safety ground to the units case you can use the yellow as a safety ground wire and terminate on the case metallic structure, but by N.E.C. only green colored wire can be used as ground wire or any wire marked with green at any place visible or connection point
Posted on Sep 25, 2009
  • daniel  hendrickson
    daniel hendrickson Oct 02, 2009
    white would be your center "N" connection neutral, yellow/w a green stripe i presume, would then be your safety ground to case metal otherwise as long as the power is supplied directly from the house main panel(NOT SUB PANEL) you can tie the white and yellow together as they are at the same potential voltage
I am hooking up a double oven to my house the wires coming from my house is black black and copper both blacks are hot the wires coming from the double oven is black red white and copper How do I hoo
The blacks are hots which wilkl give you 220 volts the bare one is the neutral conductor so the hook up the stove black to one lead red to the other white to bare.
Nov 06, 2012 | Ovens
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
Should I use 6 2 wire or 6 3 wire to my breaker box to hook up my range
You MUST use 6-3 wire and quite obvoiusly at the breaker box the red and black wires go onto the breaker and the white wire goes onto the netural bar/buss
Jul 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
Hi just wondering about 240 volt.What is the black wire and what is the red one and green and yellow....Which one is L1- N- E
The black wire is Half of the 240 volts. Both the black and red wires carry 120 volts to make 240 volts. The green wire is going to be your grounding wire. The yellow wir is more than likely your neutral wire (although that goes against the electrical code). Tie in L1 to either black or red. Attach the yellow to n. I hae no idea what the E stands for. What color and how many wire are coming from the oven?
May 08, 2011 | Ovens
WHERE DOES WHITE WIRE ON WALL OVEN GO FOR HOOK UP - WE HAVE RED, BLACK, WHITE & COPPER
white wire goes in the middle copper goes to ground or chassis
Oct 04, 2010 | Whirlpool Ovens
I have a jenn-air wall oven it has a red wire a black wire a white wire and a copper wire but coming out of my wall is only a red/black and copper what dose the white wire go to please help thank you
IF you nhave a 3 wire feed fronm the house for your range, you connect the red and black for the power and then use the copper wire from the wall to connect to the white and copper wires from the range. All new construction must have a 4 wire feed to a range and dryer.
Oct 26, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
How do i wire a newworld es50s in. I`ve been having problems i`ve conected all wires and only had 2 of the hobs working
if its 240volt and you have a 3 wire receptacle, (crows foot) and the new stove has 4 wires:i.e. a RED-BLACK-WHITE-GREEN on the oven unit, your red/black are your 2 hot wires white goes to neutral, and Green is safety ground put the WHITE and GREEN together, as long as the receptacle comes DIRECTLY from the Main Panel in the House, they use a 4 wire systen in some locations depending on local codes/any new installs require a 4 wire plug install now per the N.E.C.
Aug 23, 2009 | Ovens
What coloured wires go where on the main oven thermostat
If you are speaking of the 240v connection to hook up the oven to the electrical source, then white is the neutral(white to white), black is one of the 240v hot wires(black to black), and red is the other 240v hot wire(red to red).
Finally there is a bare or green color ground wire that goes to the bare or green wire form your source.
normally, the two outside wires on a terminal strip are the hot wires and the middle onif the neutral(white). It does not matter which wire(red or black) goes to what hot terminal at the appliance.
If you are talking about the internal wiring, I can get you a schematic of that.
Mar 13, 2008 | Ovens
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
