Question about Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder
I can insert the tape but the tape will not go down far enough for the door to shut
  • 42 Answers
Yep. I took mine to a service center for one reason and they found another. I was having blue lines appear because I did not open the latch on the tape for playback or dubbing. The service center did not help me with that but replaced what they called an UP unit which I guess is the part that raises up and down. Part was $35 and labor was 130
Posted on Aug 12, 2010
  • mydixie Aug 16, 2010
    Well I had take mine back to the service center and they said the blue lines had nothing to do with the tape tab and I guess the UP unit either they had replaced but they did not refund my money. They said the head had to be cleaned and make sure the camera has time to change temperature when moving from a hot location to colder one.
  • 126 Answers
This is a serious problem,the mech unit must be replaced.
Posted on Oct 13, 2009
How to play cassette
Hi Louise Siegel
By using the a standard Cassette Player
  1. Open the tape compartment door by pressing the eject key, usually far to the right and marked with a raised square.
  2. Insert the cassette, label side up, with the tape edge facing out.
  3. Press and lock down the play key (green with a raised circle / triangle) to start the player.
May 22, 2016 | Audio Players & Recorders
Aiwa AD-F810 when a tape is place and I try to close the door it won't but it will close and open with out any tape ? the deck is mint
i had the same type deck years ago, some decks have a two part door, make sure the outer door is clipped on to the inner mechanism correctly, may just have to be popped off. then re pop back on to inner door. jim d
Apr 26, 2011 | Samson Audio Players & Recorders
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
Rca CC9360 Mini DV Digital Camcorder
Usually this occurs when the door latch release mechanism is broken. This mechanism is located on the basket where you push the tape in and it's job is to open the tape "door" on the cassette that you insert. Unfortunately, the only fix for this is to replace the cassette basket. I know your camcorder is actually made by JVC, but I don't have access to a manual so I can't supply a part number for you.
Nov 07, 2008 | RCA CC9360 Mini DV Digital Camcorder
Insuficient clearance for caset to install
There is a lock on the door mechanism. Unless the belts are good, the machine will not recycle to move the heads down far enough for the tape to be removed, so the door is interlocked to prevent damage.
Take the case off and push the door release and watch where the release lever hits a small nylon piece. You can pushit down with a pencil or screwdriver and the door will open. This white nylon piece will stay locked down if the blets are good and do not slip. They put the door latch in park allowing the tape to be inserted or removed.
Try to treat the belts with rejuvenator CaiKleen™ RBR Let them sit a while to get rejuvenated enough to not slip and the problem should be solved.
Sep 26, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Tape eject door will open but tape will not eject
got door open and looked in and saw what looked like the tape head sitting very slightly proud of tape and believe it or not inserted a very thin and pointy bladed knife up as far as the head then pressed it down on top of the head very lightly and the head slid down its shaft to its original position switched camcorder back on and tape then ejected as per normal and it has worked normally since and as i did'nt touch the head (face?) no damage was done and it can record and play with no problems, a little unorthodox perhaps but it worked for me and saved me a probable fortune
Apr 09, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Sony hi8 ccd-trv208e pal camcorder
Same problem, same frustration. Just flashing, won't open to insert tape, Battery relatively new. Is there any way to get it to open to put in tape? I hate this technology, not along far enough.
Oct 31, 2007 | Video Cameras
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Insert the tape
There are a variety of things that can go wrong. The process of elimination starts by taking the 2 screws out of the cover and removing. While the compartment is open, push the eject button and observe if there is any motion with gears or not. The main cam gear should rotate a few degrees in one direction and then back. If you see no motion at all then you have problems that are going to require real work. Most often when this is the situation, this main gear, which doubles as the mode switch, is broken and this is a sophisticated repair to replace.
Jun 26, 2007 | Sony Handycam CCD-TR416 Camcorder
Tape door wont close
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder Logo
117 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
