Question about Hoover U5172900 Fold Away Widepath Bagless Upright Vacuum
My hoover wide path fold away automatically shuts off as if there is a clog but i have taken it apart and can not locate a clog at all....what could be the problem?
    Novelist:
  • 171 Answers
Hi there SmartAlec from NelsonVacuums.com.au here. The most common reason for this problem with this style of vacuum is that the filter is blocked with extremely fine dust. You can test this by removing the filter and running it *NOT BY VACUUMING* without the filter. Just turn it on and let it run for 5 minutes if it does not turn off then your filter is slowing the airflo down so much that it is just like a blockage and the thermal overload is kicking in and shuttin off your vacuum. I have the filters for this vacuum listed on my website if you need to purchase a new one.
Hope this helps! Happy Vacuuming :)
Posted on Sep 25, 2009
The filter chamber, pleated filter, and lid of my Hoover fold-away U5163-950 was accidentally thrown out. Can I replace it? The vacuum is still working well.
You should have no problem replacing the items noted. The below information was located in the "Service" section of the manual for this unit (found here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052463.pdf). The manual also has extensive information describing your unit.
To obtain approved HOOVER service and genuine HOOVER parts, locate the nearest Hoover Factory Service Center or Authorized Hoover Warranty Service Dealer (Depot) by:
• checking the Service section of The Hoover Company on-line at www.hoover.com OR -
• calling 1-800-944-9200 for an automated referral of authorized service outlet locations (U.S. only).
Mar 09, 2011 | Hoover U5163-900 Upright Vacuum
Does it have a reset button?
There is no reset button on this model. If the motor shut off it is due to the motor getting too hot. This can be caused by poor aire flow, usually afull bag or clogged filters. The vac is designed this way for safety.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
May 01, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
Brush on hoover wide path does not spin around.
remove the bottom cover and check the drive belt.if belt is ok then your brush motor could be bad.
Jan 29, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
I just bought a foldaway hoover with wide path. I plugged it in and started to vacuum and dust flew everywhere. Walmart would not give me my money back so they gave me another hoover foldaway with the wide...
Take to Walmart, plug it in and start to vacuum THEIR floors!
Try removing the dust container and look for anything blocking airflow including the HEPA filter. Make sure the dust cup has a seal where it joins the vacuum. The fix is probably simple, but it shouldn't be up to you to do so!
Nov 16, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
How do I replace the belt on my hoover wide path fold away vacuum
on this model there will also be 2 more screws at the top near the back on each side. the hood will come off. there will also be a cover over the roller, remove this with 3 screws, this will expose the area of the belt.
Feb 26, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Suction problem
get rid of the carpet its shredding and falling apart.no sence in vacuuming old rotten carpet.or try using a vacuum without a brush roller and just suction
Jul 15, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover Fold Awaw, U5175-900. Have had it for 4 months and from the "get-go" it has been extremely noisy especially with the atachements. Have a warranty but thought it might be a minor...
Generic problem for all Vacuums
I have a Hoover Fold Away, U5175-900
I have a Hoover Fold Away, U5175-900. Have had it for 4 months and from the get go; it has been extremely noisy especially with the attachments. Have a warranty but thought it might be a minor item I could fix.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would advise that you take it to a authorized vacuum dealer as to he would be able to diagnose the problem better than I, you typically have a one year factory warranty with the Hoover Co and if there is a brushroll / belt problem or motor than it would be covered under the factory warranty other than the belt is NOT covered, it could be something that has not been tightened down or missing some type of gasket or a bad bearing or bushing. If you have problems contact the Hoover Co for a dealer nearest you, or look in the yellow pages for a vacuum dealer nearest you.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 21, 2008 | Vacuums
Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Dec 25, 2007 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover U5172900 Fold Away Widepath Bagless Upright Vacuum Logo
133 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
