Question about Proform CrossTrainer Treadmill
I just put a new belt on my Pro-Form treadmill. When I start it, it runs for about 3 seconds, then it stops and gives me an E2 error code. What does that mean?
Hi there
sanjay treadmill repair professional from india
you have done some mistake when you fixed the new belt.
You have a speed sensor problem.
CHECK
1.Front roller sensor usually a magnetic one for broken wire or for larger space between the magnet and the sensor.
i) Sensor is Usually 2 wire and magnet is fixed on to the roller.
ii) Magnet can dislocate from its place check the magnet for attraction by taking a screw driver.
iii) Chcec gap between the magnet and the sensor on the frame. Gap should be betwwen 3mm to 5mm.
2. If roller sensor is not present then there is alternative sensor on the motor ususlly a multi holed plate revolves between the sensor.
i) It is usually has 3 wires.
Check for the connections on the motor control board.
If not solved then mail me on sanjay_phil@yahoo.co.in
Posted on Oct 02, 2009
    Problem Solver:
  • 5 Answers
That the belt is to tati or to lose
Posted on Sep 24, 2009
2 Suggested Answers
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
My preform treadmill isn't starting, how do I fix this problem?
If it tries to run for a second or two and stops it will probably be the speed sensor. It is a small magnetic switch that is activated by a magnet on a flywheel that drives the belt. The control board looks for this signal to set the speed of the belt, without the signal the belt will stop. A competent DIYer could probably find and fix it but make sure the machine is unplugged from the wall before attempting any work.
Oct 05, 2014 | Proform Nordic Track Treadmill Pro Form...
Slipped belt
there are two bolts on the rear of treadmill walking deck. these are adjustment bolts. start with the belt going 3mph. tighten the side where the belt is closest.only go 1/4 turn at a time.give it 15-20 seconds for belt to track or move over. continue until centered.
Apr 17, 2014 | Proform Pro-Form 520 ZN Treadmill
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
My belt is skipping on my Pro-Form 750
At the end of of the running belts in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 01, 2010 | Exercise & Fitness
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Jul 14, 2009 | Exercise & Fitness
Proform CrossTrainer Treadmill Logo
544 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
