Question about HP Compaq Presario C500t Notebook
Compaq computer running vista trying to add a printer message local print spooler is not running I have started the print spooler through admin tools but everytime I close the control panel it must switch off again anyone got any ideas???
  • hazelmccann Sep 25, 2009
    thanks for your solution I have tried all this twice but I will go and try again.
    Novelist:
  • 148 Answers
Start the simple route: uninstall and reinstall the printer and its software. If the software is old, head to the printer manufacturer's website and download the latest driver package.
Meanwhile, track back to when the print spooler worked successfully. Was there any new software installed that may have caused the problem? A possible update from Windows, perhaps?
Posted on Sep 25, 2009
Where i could see the printer spooler?
I open the run command you can type: net start spooler
(You will get a message that says the print spooler service has started)
If you still have issues open the run command and type: services.msc
it will display a list, where you can find print spooler.
From there you can right-click on it and set it so it is started and runs automatically.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 25, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
I still cannot print
Reboot the computer if the printer is local. Or, type services.msc in run / search. Scroll down to Print Spooler and start by right clicking. You have a bigger problem if this fails to start. Like you may not be an Administrator.
Starting the Print Spooler on a networked printer (at work) is the same, only it must be done by an IT admin on the Print Server.
Dec 10, 2012 | Computers & Internet
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
I am running vista ultimate 32-bit but i often received this error message:".....the local print spooler is not running...." when attempting to install a remote oki B4400 printer. Why is that?
Print spooler is printer service if this service is not running, it might not allow you to add or see any printer drivers
Try enabling print spooler service. Follow the instructions
Click on Start->Search->type "services.msc" hit enter. Service windows will open up, on the right side pane search for "Print Spooler"
-> double click to open service and select start type as "Automatic"
click on apply and click on "Start" botton to start the service.
Now try to install the drivers
Snapshot for more information.
Hope this helps
May 21, 2010 | Computers & Internet
PRINTER AND COMPUTER WERE WORKING OK. SUDDENLY WHEN I WANT TO PRINT A MESSAGE SAYS:WINDOS CAN'T OPEN . THE LOCAL PRINT SPOOLER SERVICE IS NOT RUNNING.RESART THE SPOOLER OR RESTART THE MACHINE. WHAT'S THE...
Print spooler is a service (part of OS) which basically sorts out the info to be sent to the printer to perform the printing task.
To turn on in XP go to Control Panel/Admin Too;s/Services (in classic view) or Control Panel/Performance & Mainainance/Admin Tools/Services.
Scroll down to Print spooler and double click. In the box that opens start up type should be automatic. You can also start the service from this box.
I preume Vista will be something similar.
Mar 24, 2010 | Acer Office Equipment & Supplies
Error on inkjet "print spooler service not running"
hi, friend. You need to re install your Printer software CD because the program corrupted. thats the only way to solve that.
Apr 08, 2009 | Compaq Inkjet IJ750 Printer
Print Spooler service not running
Go to Start, Control Panels, Administrative Tools, Services.
Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
Right click on the print spooler and select Properties.
Click on Dependencies to view a list of all the system components that the print spooler depends on.
Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Nov 19, 2008 | HP Compaq nx6310 Notebook
1020 Spooler SubSytem
ok, so for this, always had an issue with this one,
so, what i did is started the spooler, the way to do this is you have to go into control panel>>>admin. tools>>> services>>>printer spooler>>> and then you have a blue icon on your left where you have to click on the button that says start the spooler, now i recommend you minimize this window,
next step is that you add the printer through the add a printer wizard in most cases the printer should already have the basic driver installed into the computer. and way to add it to to start the add a wizard, click on add a port make sure the box where it reads plug in play is unchecked, so the only icon you have checked is the local port, next you choose the port that is usb001 from here you choose hp>>> then laserjet 1020, let the printer driver install and finally your done.
Jul 09, 2008 | HP LaserJet 1020 Printer
Printing Error
Try this:
1. Power off the printer
2. After re-boot: click start, control panel, printers & faxes and delete the printer.
3. Re-install the printer with the original driver disc.
There are many suggested solutions to spool problems but try this first. If this does not work we'll go to the other solutions.
Mar 30, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Computers & Internet Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
