About the Polar Wind Portable air conditioner: When the compressor tries to kick on it just shuts off again. I tested the start and run capacitors and they tested fine. The coils are clean. The water basin is empty. I can't find any other information on it and don't know if I can buy a part if I did find something that was wrong. The only thing left that I know it might be is the circuit board or a bad winding in the compressor. Any suggestions? Any contact numbers? Thanks
  • nannybuzzby Sep 24, 2009
    Don't have a clue how to check the head pressure or what it should be....do you think this unit is junk?
    President:
  • 3,433 Answers
Have you chk'd the head pressure of the condensor?
Posted on Sep 24, 2009
  • Ned C Cook
    Ned C Cook Sep 25, 2009
    I wouln't junk it until it was diagnosed. The only way to ck it is with gauges. You said you ck'd the start and run capacitots?Where doyou live town, I'm in Mira Loma. 909-630-3192Ned I am not a store
APE08AJM1 - GE 115 Volt Portable Electronic Room Air Conditioner - Compressor not kicking on. Manual indicates it's triggering the overload relay? How do I solve this?
There is a start capacitor near the compressor that may be bad. If the capacitor tests OK then the compressor is locked up. A service man can try to get it going with a kicker capacitor but there is no guarantee that that will work.
Sep 14, 2017 | GE Heating & Cooling
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Fan runs but compressor just humms and wont kick on
Check electrical connections including the contactor. Also test the capacitor. If the capacitor fails, it will prevent the compressor from starting. Click HERE to see images of what the capacitor looks like.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
My RC air conditioner (Duotherm) kicks the circuit breaker every time I turn it on. It used to kick the circuit breaker every so often, but lately it kicks it immediately if I try to turn on the AC.
Try replaceing the start or run capacitor to the compressor. If no help you can install a start assist capacitor, it helps to start a tight compressor.
Sep 10, 2009 | Dometic Rooftop RV Air Conditioner
I have a ARP-30125 portable A.C. just about 1 yr
try a hard start electronic relay(it has a big capacitor to give it extra kick to start) clean both fins...oil fan motor
Aug 18, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Compressor will not start but the fan runs on RV air condition unit Mod 7332B896 Coleman
If you can hear compressor try to start, then kick out, then I'd say capacitor needs replace, but if you don't hear anything (moan or groan) from compressor, then I'd be looking at a new relay, or at least testing it.
Jul 30, 2009 | Dometic Rooftop RV Air Conditioner
Compressor tries to kick in but then stops.
it is a hard start compacitor, the unit is not supposed to have three compacitors.
Apr 11, 2009 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
783 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
