Question about Kodak EasyShare One Digital Camera
Can't get on Easyshare
When trying to get on my Easyshare message says turn off compatibility mode. How do I do that? Easyshare appears to be running in a compatibility mode for an older version of Windows.
  • 101 Answers
Try the steps below.
1. Right-click the EASYSHARE icon on your desktop
2. select Properties.
3. Select the Compatibility tab.
4. Clear the Run this program in compatibility mode check box.
5. Click Apply, then OK.
Thanks.
Regards,
Neerak21
Posted on Sep 24, 2009
    Sergeant:
  • 151 Answers
For this problem
Right click on the easyshare icon then select properties
Under the properties window select Compatibility tab
Clear all checked items
run Easyshare software
Thanks
BYron
How Do I TURN-OFF "COMPATIBILITY-MODE" in Windows 8.1
Right click the setup.exe go to properties and you wil be able to turn off compatibility mode off there
Nov 24, 2014 | Computers & Internet
I recently purchased a new computer (HP/Windows 7) and am having difficulty loading my copy of PDFCreate!3. The error message is: "AddPrintDriver Cause of Failure - 2". Is this version of...
hi,
it does appear that even create 4 didn't have windows 7 support. You may try installing and then changing to windowsxp compatible mode by right clicking the icon and selecting properties and the compatibility tab then place a check in "run this program in compatibility mode" and choose windopws xp. and or install virtual PC with windowsxp compatible then install and run your older software in a virtual machine.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 08, 2011 | Computers & Internet
I purchased Egames Lexicon. When I try to install it a message appears that says it cannot start or run due to incompatibility with 64-bit version of Windows. How can I get this software to work on my...
Right click on the executable file that starts the setup, typically setup.exe. Select Properties. Under Compatibility, set it to Windows XP SP3. If that doesn't work, it really won't work without you setting up a virtual machine and installing a copy of XP. If you're running Windows 7, you can download a Windows XP virtual machine to run. It's called XP Mode. Instructions can be found by searching for XP Mode in the Start menu's Help and Support.
Jul 06, 2011 | E-Games Lexicon Word Challenge for Windows
The program locks up with a message that " Macromedia projector has stopped working" but the message does not appear for a variable length of time. This is a Vista machine with a wide screen...
If you are running Windows Vista:
Right-click the 'hearts and spades' icon and select Properties from the context menu
In the dialog that appears, choose the Compatibility tab, switch on Run this program in compatibility mode for: checkbox and select Windows XP (Service Pack 2) from the drop-down list
Click OK thanks ... have a nice day.
Mar 10, 2011 | Computers & Internet
Error 50 appears when trying to open itunes after update install
Uninstall it, then Unblock the setup before you run it,(right click on the setup, Unblock/Apply. Temporarily turn off any Antivirus program when you re install it. And you can run it in Vista compatibility mode, see if you still get any errors then. (right click on the programs icon, properties, compatibility tab, Run this program in compatibility mode for: Vista SP1/Apply).
Feb 26, 2011 | Computers & Internet
Want to install hp deskjet 1560 driver on windows 2003 server
right click the driver setup file and click on properties. In the properties window go to compatibility tab and choose 'run this program on compatibility mode' and select windows xp. Now click and try running the setup again. Hopefully it might help you solve the problem.
BestRegards NextDoorNerd
Jul 28, 2010 | HP Deskjet D1560 InkJet Printer
Itunes .exe has been set to run in compatibility mode for an older version of windows. i already tried to change version but cant find windows 7 version also turned off compatibility still no luck
Unfortunately, even though I'd turned off compatibility mode for iTunes (by right-clicking the iTunes icon, choosing Properties, clicking the Compatibility tab, and clearing the Compatibility mode checkbox), the program generated this irksome message every time I ran it:
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
Sigh. Stupid Windows. Or maybe stupid iTunes. Either way, compatibility mode was "off," but iTunes didn't think so.
Fortunately, I finally found a solution:
1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Dec 16, 2009 | Apple iPod MA446LL/A MP3 Player
Kodak c913, error When using easy share software,
You need to rebuild the picture catalog. Pls. follow the steps below to perform the task:
  1. Right-click the Kodak EasyShare software icon on your desktop, then select Properties.
  2. Select the Compatibility tab.
  3. Clear the check box for "Run this program in compatibility mode for" then clear all the check boxes under Display Settings.
  4. Click OK.
  5. Right-click the Kodak icon in the system tray, then select Shut Down Kodak EasyShare software.
  6. Go to C:\Program Files\Kodak\Kodak EasyShare software\bin.
  7. Right-click the Catalog folder, then select Rename.
  8. Change the folder name to OldCatalog1, then close the window.
    Note: If you cannot rename the folder, go to Part B.
  9. Select Start > Run.
  10. Type %temp% in the Run dialog box, then click OK.
  11. Open the _Retain folder (if there is one).
  12. Double-click the bin folder.
  13. Right-click the Catalog folder, then select Rename.
  14. Change the folder name to OldCatalog2, then close the window.
  15. Delete the backup catalog files ESBK.mb and ESBK.mbb:
    a. Select Start > Search > All files and folders.
    b. Type ESBK in the All or part of the file name box, then click Search.
    c. Delete the two files found (ESBK.mb and ESBK.mbb).
    e. Click Yes to send to the Recycle Bin.
    f. Close the Search Results window.
  16. Delete the EasyShare.mc file.
    b. In the All or part of the file name box, type EasyShare.m
    c. Delete any .mc files found.
  17. Restart EASYSHARE Software.
Jul 03, 2009 | Kodak EasyShare C913 Digital Camera
Itunes
Hey 0836,
If the error message you are seeing reads as "QuickTime failed to initialize. Error # - 2096" you may wish to turn off Compatibility Mode for QuickTime, as doing so may resolve this problem.
You should be able to disable Compatibility Mode by doing the following:
1) Right-click on the QuickTime Player program and choose the "Properties" option from the menu that appears. Normally the application is kept in the C:\Program Files\QuickTime directory, but may differ if you chose to have the program installed onto another hard drive or in another directory.
2) Once in the "Properties" menu, click on the "Compatibility" tab.
3) Uncheck the box that says "Run this program in compatibility mode" if it is currently selected.
4) Click on the "Apply" button.
If QuickTime was not initially in Compatibility Mode, and you still receive an error message prompting you that iTunes requires Windows 2000 or later (or prompts you to make sure that compatibility mode is disabled in iTunes.exe), you may wish to try the following instead:
1) Shut down iTunes.
2) Click on the "Start" menu, then on "My Computer." You can generally also double-click on the "My Computer" icon on your desktop as an alternative.
3) Once in "My Computer," open the drive where Windows XP is installed. Typically this is the C:\ drive, but please remember that your configuration may slightly differ if you have multiple hard drives.
4) Open the "Program Files" folder.
5) Open the "iTunes" program folder.
6) Next, right-click on the iTunes program - this may be listed as either iTunes or iTunes.exe. Once you have done so, choose "Properties" from the menu that appears.
7) Click on the "Compatibility" tab, and uncheck the option to run in Compatibility Mode if it is selected.
8) Click "OK" to accept the new settings.
One of these two solutions should hopefully resolve the problem, but I would strongly suggest visting Apple's support homepage for more information if you are unsure of how to proceed.
http://www.apple.com/support/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Apr 13, 2008 | Audio Players & Recorders
Kodak EasyShare One Digital Camera Logo
75 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
