Question about ASUS P4S333VM (AP4SRRVM) Motherboard
Pci slot seems dead
When i try to plug new PCI D-LINK LAN Card and VGA AGP PixelView Card it doesn't take any effect. windows (XP Prof) can't detect any new hardware device.
why is really trouble that I have now? and how to fix it?
Thank's so much
    Problem Solver:
  • 18 Answers
So windows XP doesnt detect your new hardware. Try these suggestions:
1. Re install by reconnecting it to their respective slots.
2. Check, if the cards connected, supports PLUG and PLAY which means it can be detected automatically if connected to the slots.
3. If it is not plug and play, you have to configure it manually, try to install its software cd.
To see if it is already detected, go to the my computer and check the hardware devices connected menu (I hope you can browse to go to that menu) next, if it is already detected
all items listed there must have no question mark on it and X mark.
If you have this mark, it means that the driver is not installed yet or you have to reconfigure it.
Posted on Dec 17, 2007
ATI Radeon 109-70600-20 driver needed
Hello the driver can be found here:
http://support.amd.com/us/gpudownload/windows/Pages/auto_detect.aspx
By installing AMD Driver Autodetect detects your graphics card and Windows operating system.
The info about the graphic card, can be found in the device manager.
Good luck
Feb 23, 2013 | ATI 109-70600-20 AGP RADEON VGA 32MB
I install new video card GT240 and the computer cannot detect the new hardware only blank screen can be seen but the harddrive is working and you can here it boot up
if you had an onboard graphics card, one that was built into the motherboard then connect the vga lead back to that and see if you get an image on the screen then. If you do you will need to go into your bios and under advanced options change the default vga to pci/agp
then when windows starts it will start from your new graphics card and not your old one
If this was helpful please vote
Feb 24, 2011 | Acer Aspire m5640 PC Desktop
I have a Dell dimension 4300 running Windows XP SP3. The system has 1 Gb of RAM. I removed the AGP graphics card that came with the system and installed the VisionTek Radeon 256M X1300DMSPCI card into a...
Yes, it is compatible, just that you must first uninstall the previous video driver, then configure the BIOS to route the video signal to the PCI and not the AGP and only then install the new card. And in the end it will behave worse than the previous AGP card you got because the PCI interface is way slower than the AGP.
Just buy a good AGP card, PCI cards are made for office pc's in which the onboard one is totally obsolete.
Feb 08, 2011 | VisionTek RADEON X1300 , Graphic Card
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
When I plug my monitor into my video card i get "no input signal" yet if i plug it into the onboard slot it works.could my PCI-E slot be bad?
Did you add a video card? If you have an AGP slot, it is best to put the video card in it. If so you need to go into the Device manager. Remove, disable or uninstall the onboard VGA driver. Go ahead and remove the PCI video card driver as well. Power down PC. Make sure monitor is hooked up to the Video Card, not onboard VGA. Power on PC. When Windows loads, it should detect the VGA card first, but if it detects the onboard first, ignore and don't setup onboard first. When Windows detects the card, load the necessary drivers when prompted. There is no need to reinstall the onboard driver for the video unless you wish to hook up two monitors.
Nov 08, 2009 | HP w1907 LCD Monitor
No video from the board
Check the motherboard user guide for how to reset to default factory settings. If the BIOS is set to work with the on-board only and the on-board VGA is dead the motherboard is supose to detect that and switch to AGP. If is not doing that chances are not only the on-board VGA controller is gone ... the motherboard is gone too.
Try with a PCI video card.
1.Reboot with the AGP or PCI video card installed - assuming the on-board is gone but the motherborad still OK.
2. Press DELETE key
is supose to go in BIOS settings menu.
Browse and Look for on board VGA adapter ENABLE/DISABLE setting or something similar.
(My bet ? You need a new motherboard.)
Jan 12, 2009 | Intel Motherboard
VGA PCI bus
This motherboard does not have the advertised chip set on it. Instead of the SIS 761GX and 900 lan, it has the SIS 740GX and 190 lan. I had exactly the same problem and I wasted three days searching for the solution. Either the board is mislabeled or Foxconn conned everyone with a lesser chipset. The correct drivers are readily available at http://www.sis.com/download/ .
Aug 28, 2008 | Foxconn 761GXK8MB-RS Motherboard
Problem to find correct Drivers for Windows XP Prof
Try doing windows update. Look for the +Hardware tab when you go to the update website. That usually gets 99% of the drivers.
Aug 18, 2008 | HP Compaq nc4010 Notebook
VGA
hey
first check ur motherboard have builtin VGA or not. If its builtin vga first disabled the builtin and then install ur ATI vga card on ur AGP or PCI slot it will automatically detects and ask u to install the driver for it
Feb 24, 2008 | ASUS K8V SE DELUXE,...
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
