Tv turns on red light shows then shots no sound no picture
  • 1 more comment
  • williamlawre Sep 24, 2009
    you asked for modle number is-tv040919 brand is insignia
    insignia tv modle is-tv040919 tv turns on red light shows then shots off after a few seconds
    do i need a flyback transformer and a horizontal output transistor?
    Brigadier General:
  • 7,191 Answers
Your problem dated 24 Sept 2009 was re-posted today. If it has been already resolved, kindly ignore this message.
Thanks for using FixYa
Posted on Aug 09, 2010
  • 10,515 Answers
Let me be on point. The generic solution would be Lamp ( If it's more than one year ).
Friend the easiest way to tell, would be to pull lamp out close door tightly turn unit on listen for the ballast to make the buzzing noise if it does it completed its cycle and you just have a bad bulb that looks good. And also do this test Were the wire is that runs from the ballast to the power supply, make sure it reads around 300vdc if it doesn't you need a power supply if it does you need A BALLAST. You can make sure the capacitors close to the connector are flat on the top if not you may have bad capacitors.
The pictures of Ballast :-
http://images.google.com/images?gbv=2&hl=en&sa=1&q=dlp+ballast&aq=f&oq=&aqi=&start=0
The pictures of Capacitors :-
http://images.google.com/images?gbv=2&hl=en&sa=1&q=electrolitic+capacitors&aq=f&oq=&aqi=g-sx1&start=0
If not,
A POP from the TV could be just about anything. Sometimes capacitors swell up and burst. Most likely you are dealing with a shorted IC, from the churping sound I can tell that the switch-mode power supply is over-loaded.
From the sound of your problem you should probably call for service. There are too many variables involved to diagnose a problem such as yours over the internet. Modern TV's have thousands of parts, it can take a seasoned veteran up to an entire day to track down troublesome problems IN PERSON.
Please understand that by opening a TV you are exposing youself to many dangers, including electrocution. Be sure that the set is un-plugged and keep one hand behind your back whenever possible to avoid a shock through the heart as this CAN KILL YOU. If you have zero electronic experience I would not attemp this repair. OK, public service announcement over.
Basic electrical knowledge is a must to get inside your TV and fix it.
Your TV will need some parts and it is best to either leave it to a technician to diagnose.
If you call for service prepare to part with $200-$350 depending on the damage in the TV. It may be prudent to buy a new TV if this one is over 7 years old.
Let me know if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 24, 2009
  • taran_2005
    taran_2005 Sep 24, 2009
    Oops!!
    I did not read the comments so i was not aware that this is not a PROJECTION TV.
    For your model,
    The TV not starting properly you should hear the tone noise (bleep bleep) not a ticking noise or no sound.
    A long time coming on is a classic example of what I am detailing for you below. .
    These LCD's have problems with the power supply capacitors going bad,
    a servicer will charge between $200 and $450 to repair it replacing
    either the capacitors or the whole board.
    here is a DIY (do it yourself) solution:
    It
    could be just a few bad capacitors on the power supply, if you want to
    attempt the repair yourself you can do a visual of the power board caps
    will appear swollen on top.
    We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.With
    the back removed you will usually see two circuit boards the upper one
    is the power supply, it has a few capacitors on it (cylindrical
    standing straight up soldered in mark on the sides with the
    positive/negative sides and MF and Volts values.
    The
    power board and back unscrew with a medium philips screwdriver, if you
    do not know how to desolder and resolder then do not attempt this as
    you may damage the TV more than fix it.
    I am posting a photo link of some swollen caps on a board so you know what they look like here.
    Hope i helped you.
    Thanks.
  • 10,594 Answers
What is model number and brand of your TV?
Provide me model and brand of your TV to know and find out possible reason of problem.
Thanks.
  • Shahid Electronics
    Shahid Electronics Sep 24, 2009
    OK, it is 20" analog CRT TV and problem seems in horizontal deflection circuit, need qualified tv tech as it is not user level repair.
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
Red blinking light turns off picture and sound
The TV needs repaired by a professional, but sounds like the motherboard is shot.
Dec 07, 2011 | JVC AV-27D500 27" TV
My name is shakena brown, i have a sanyo 32in flatscreen TV that I brought from Wal-Mart. The TV is not an year old yet and it will not show anything. When I plugin the cord in and turn the TV on the...
Your set is still under a manufacturer warranty. Take your set back to Wal-Mart and they will send it out to be repaired, or give you a new one.
May 19, 2011 | Sanyo Televison & Video
Standby red light just continuesly blinks, no picture -
TV TURNS ON 1-2 SEC SCREEN SHOWS COMPONENTNT1 AND TURNS OFF WITH A POP SOUND FRO9M SPKRS
May 17, 2009 | Akai LCT2701TD Television
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
Samsung TV stopped displaying picture
No picture but sound can mainly be of two problems, most of the times it is caused by a faulty vertical deflection ic, you can diagnose this by slightly increasing the screen voltage by turning the screen control on the LOT, a horizontal line will appear if the vertical ic is shot, and the other problem is the CRT base, but this is less common for shot base won't go off at once, it will show picture faded in the beginning. Now another problem could be the horizontal output transistor, if the tv has a high power sound output, the sound power supply will come from smps itself instead of from LOT, check that too, to confirm this, check if the CRT filament is glowing. Good luck.
Jan 17, 2008 | Televison & Video
Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
