Question about DeLonghi 9707 Oil Filled Radiator Heater
Burning smell from oil heater
Last night there was a burning smell from the heater half an hour after turning it on. Next thing I know the heater had stopped working and wouldnt warm up no matter what.
  • 6,927 Answers
Pull the controls off the front,and inspect the thermostat connections to see if they are burned up,also the other switches will do the same thing.If you can`t see a problem,then the element is burned out,throw it away and buy a new one.
Posted on Sep 24, 2009
Creda 79141c
Turn it off and have it checked by a registered electritan. Please DO NOT use it until you have!
Jan 28, 2014 | Heating & Cooling
Burning smell
check belt
Jan 09, 2018 | Dryers
Will not turn on. Unit has been working great until tonight. Was on but now off and will not come on. Unpluged it for an hour but still not working.
This same thing happened to me, and yesterday as well no less. I've had mine for a 3-4 years. I think It had run out of oil, which is weird because I've had a Holmes heater for nearly 10 years and it still has plenty of oil left. If you shake it, can you hear the oil? I went and got another from Target last night (it was the coldest night of the year) and can hear the oil swishing around in it as I set it up. Hope it last longer than another 3-4 years or my next one will be a Holmes.
Jan 22, 2011 | Honeywell HZ-709 Oil Filled Radiator...
I bought a Sunbeam Heating Pad (Ultraheat) last year which I just took it out of the box last night. It is brand new, not used until last night and it smell like it was burning. I instantly unplugged it....
Sorry to read about your problem, I hope this helps you out.
i think from sitting in the box for a year, the material can smell, form its first time usage.
I suggest you put the pad on or in a baking dish on the stove..plug in and see if the smell burns off. I think it will.
if not return to Sunbeam (800) 435-1250
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Sunbeam 722 Heater
My dynaglo kerosene heater will not continue to burn. It is full of fuel and will light but will not burn. what could be the problem?
Many things can cause this to happen and here are a few of the most common. The wick could be dirty, wicks should be brownish black in color, soft to the touch and flexible. Wicks will get hard and full of soot, my solution is to clean the wick with an old tooth brush gently brush it and I do this with the wick up about half way so I do not damage it. Then I take a shop vac and **** out all the stuff from the wick, make sure it still moves from high to low easily. Now soak the wick for roughly a half an hour and then light it. If the cleaning does not work you will have to change out the wick and remember that soaking the wick is the most important thing to getting good life out of it. Another practice is to burn out your heater each four to five tanks of fuel, this does stink bad so when you do this do it outside. Once you notice that you are about out of fuel take the heater out side and just let it burn out, this does clean the wicks on these heaters. Fill with K1 kerosene soak for the half hour with the wick completely turned down, then set to high and light it up. This cuts down on smell, helps it burn hotter,and in turn burns more efficiently.
Dec 26, 2010 | Heating & Cooling
1999 expedition- After driving for a half hour or so the engine smells like a faint burning smell but the temp. gauge inside reads normal. I also can not get any hot air to come out with the heater on even...
No heat usually means low water level in radiator. Check your plastic surge tank to see if is at the proper level. When engine is cool check actual level in radiator.
For smell check to see if any oil is weeping from top engine gasket and dripping onto exhaust manifold, You should be able to check with flashlight while engine is idling.
Nov 23, 2010 | 1999 Ford Expedition
Kelvinator Inox Freezer not switching off
hi! theres no funny when you smell burning please switch off the power and you che
Jan 20, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
SAMSUNG HT-X50
Do you smell anything burning. This happened to me and I cut it back on. It stayed on for 30 secs or so and did the same thing. After doing this 2-3 times, I smelled a burning. Being a member of the Fire Dept, I didn't want to see my buddy's coming to the house, so I unplugged it. The next day, I took it apart and there was a burnt resistor or something under neath the fan. I took it back and they gave me a new receiver, but I'm expecting the same with this one.
May 16, 2008 | Samsung HT-X50 System
DeLonghi 9707 Oil Filled Radiator Heater Logo
1,041 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
