Question about NEC Lands Phones
We have an NEC Univerge SV8100 (v.2.50.03) with UM8000 voicemail (v.11.1.1.28) in our office. The receptionist connects via a PC running the latest NEC Desktop program. Her headset is a Plantronics CS50 USB wireless. Sometimes, a beeping will start in her headset. The only way to stop it is to close the NEC desktop program and re-open it. If she DOESN'T do this, and lets the beeping continue, eventually, callers cannot hear her when she answers the phone. Also, the line indicator colors do not sync after closing and re-opening NEC desktop program.
SOURCE: EXECUTONE MODEL 64 Phone
quick way is to delete them both and re-record
Posted on Aug 09, 2007
leethedeuce
  • 4472 Answers
SOURCE: Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Posted on Jun 17, 2008
  • 149 Answers
SOURCE: Connect/Program Headset
Sure you can do it. as long as the headset has a plug for the handset your fine. Plug it in and you will have to pick up and hang up the handset as needed. The headset key eliminates you having to pick up and hang up the handset to answer with the headset.
Posted on Nov 18, 2008
keekus
  • 83 Answers
SOURCE: Have the 6408D+ phone. Got a Plantronics CS55 Wireless Headset.
You can use an handset lifter accessory, such as the HL1 or HL10 to pick up the handset every time you need to use the headset.
Posted on Jul 18, 2009
  • 3 Answers
SOURCE: How do I access the
Need to be on the programming extension. Select "VMsg", enter password, then select to "more"
Posted on Sep 08, 2010
Wanting to extend ring time - changed by itself - only ringing 5-6 times before going to message bank.
5-6 rings I think that is the best you can get
link to a manual for it
SV8100 DT310/DT330/DT710/DT730 User Guide - NEC Corporation ...
https://www.necam.com/Docs/?id=5601ae16-b7e2-4e8c-a769...
NEC-10645 UNIVERGE SV8300 DT300 DT700 USER GUIDE
au.nec.com/.../SV8300_Handset_Manual-ce03fb6c-32af-4991-9bd5-8ec.
Sep 09, 2016 | NEC Dtl-12d dt330 12-button Digital...
My NEC DVL(XD)Z-Y (BK)phone has a red blinking light for reception button. No one knows the mailbox code since the receptionist was replaced. How do I reset code or stop light from fast flashing red?
These instruction are for a Univerge-SV8100
To Delete a Security code, the greeting, messages or recorded name in a personal voicemail box:
1. From any phone with Admin rights (Usually ext 101)
2. Press the message button
3. Enter security code if there is one
4. Dial 72 to access System Admin
5. Press SUBS soft-key (in display)
6. Dial the extension number you want to change
7. Press the available softkey in the display or 7 to delete the security code.
Be careful when you are in the admin part of the programming because you can really mess up the voice mail if you do something wrong. To check what type of phone system you have look for a NEC box in your phone room or server room. The complete PDF is here
http://www.integratelecom.com/resources/Assets/sv8100-admin-inmail-master-11-5-07.pdf
Jan 23, 2015 | NEC Lands Phones
How do I access my voicemail box from outside of the office?
There are 3 ways to access your voicemail:
1. Call into the main office and have the receptionist transfer you to your mailbox.
2. Call into the main office and if you hear an Auto Attendant, select #. Then, enter your mailbox number and password.
3. If you know what number your voicemail is tied to, then you just call the number, select #, and then enter your mailbox number and password.
If none of these options work, then whomever programmed it may have turned it off and you may need to contact the tech.
Sep 18, 2014 | Comdial Impact Telephone
Program headset in to NEC DT300 phone
how do i connect head set in nec dt 300 series phone ?
and is there any configuration needed for that ?
Mar 27, 2013 | NEC Univerge Dtl-12d-1 680002 Dt300 Refurb...
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Voicemail won't allow recording transfers back to receptionist!
Are the mailboxes set up?? What happens is a call goes to an extension, there is one program set to tell the system that if a call rings 4 times, go here(voicemail). Once it goes there, the voicemail system sees that there is or is not a mailbox matching that extension. If there is, the call goes to voicemail, if not, it transfers to the operator.
OR.....Does your system display the correct time? Its possible that the phone system lost its programming, and doesnt know where the voicemail is.
Both might need a professional tech on site...a bit too hard to help over a forum.
Mar 20, 2009 | Lucent PARTNER18 Corded Phone
NEC DTU-16D-2 Phone manual
Here's the manual for all NEC Electra Elite =>
http://www.chickasawtel.com/pdf/manuals/elitemultilineug.pdf
Please leave a Helpful or FixYa! Rating. Thanks!!
Sep 29, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Unlocking the security cide to access teh mailbox?
Find out who has administrator access (usually extension 100) and use that phone, call voicemail, press "more" press "MGR" press "CHBX" listen to the voicemail which will prompt/ask you if you want to delete the security code. Say yes!
Nov 06, 2007 | NEC DTU 8D-2 Corded Phone
Lands Phones Logo
600 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
