Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I having problems with my computer board and the machine is no longer working. How much to get to get it fixed?
  • 6,784 Answers
HI. this board has a history of breakdowns. You can try a hard reset if possible. this may reset the board.
Simply unplug or shut down the appropriate circuit breaker for five minutes. this may revive the board. If this does not produce positive results, the Board should be replaced.
The cost for the parts will be $160.20. it can be purchased online at the repairclinic.com
The labor charges, if you choose to call for service, will be 50 dollars an hour at the most.
Posted on Sep 24, 2009
I have a CPU with burnt fuse and board looks smoke damaged wondering whether to replace fuse or entire CPU?
fuse costs about fifty cents , board costs over two hundred , but I would say smoke damage is leaning more like the board me ! Id have a small appliance tech look at it , if there is other parts ruined I missed id rather pay him his diag fee than waste money on a two hundred board that's not going to fix it ! It would go towards a new one
Sep 29, 2016 | Nuova Simonelli Premier Maxi Espresso...
Kitchenaid dishwasher Kudio1il 24'stainless steel. Problem with control panel. Dishwasher will not start. Only NORMAL button, HI-Temp button, Energy Saver Dry button, and cancel button light up when...
I'm having similar problem.I uploaded video of my attempt to reset and problem that I have after.I've already tried replacing my board... but have the same problem. The board was a refurb... so not sure if the board sent was defective - or if the problem is the control panel or something else?? thoughts?https://www.box.com/shared/ef486b70331cd4462ed6
Oct 05, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Machine only shows straight lines on screen and print.
you either have 1. a defective patient cable, or 2. a defective PC board. The internal problem is very likely the input connector its self, buy this is a multilayer board, and requires an experienced hand with a soldering station. Also note that if the problem lies elsewhere on the board and the board has been worked on in any way, Schiller will no longer exchange it. A new PC board(aprox2200.00) would be your only option. IF the board is returned to Schiller having never been worked on, they will exchange it for around 800-900 dollars. A far better deal./
Sep 28, 2011 | Schiller Welch Allyn Cardiovit At 2...
My Pfaff 7570 will not run. Thought it was the foot pedal. Tried a new one which also didn't work. Changed the AA batteries.Display lights,but will not sew. Husband thinks it is some kind of...
Could be motor brushes or a bad base plate board circuit board. That is a great machine but may be hard to find someone to fix this problem. Take to only to a pfaff repair shop. Motor brushes should be around $50-100 repair and base plate could be up to $500. I would also check it with a nother foot control just to be safe.
If your husband wants to do the job here are some tips.
The motor is right behind the display board, you will need to remove the diplay and motor to get to the brushes.
For the base plate board, Remove the 4 large flatblade screws to get the base plate off.
Right next to the trasnformer there 3 small fuses, (they are back and say fuse on them) if one is very carroded and white there is a good chance that is bad and replacing it will fix the probem.
Lots of work for bolth if the repairs and I recomend you take your machine in.
Apr 03, 2011 | PfaFF Creative 7570
My wonderful Bernina 1130 has served me loyally since purchase in 1988, often being used every day when I worked as a dressmaker. In recent years full-time work keeps me from sewing. My faithful Bernina...
Contact an authorized Bernina dealer/repair center. The service technician can often tell what board needs to be worked on, take it out and send to Bernina. I just had to have work done on my 1130 and that is what was done. If that does not work, look up the number and call Bernina USA directly so they can direct you. While it's true that some parts are no longer obtainable, the machine boards can be serviced by Bernina USA. It's worth fixing.
Sep 29, 2010 | Bernina Virtuosa 160
Started making a clicking sound (coming from the back of the frigde). All the lights and panels still work, however whenever there is a click, all the lights flash; things no longer staying cool
you have a bad computer board,it's on the back wall of the machine.the board is around 200 bucks,g.e. has had alot of problems with the boards and everything goes through the computer board.most likely it will be the board or the compressor could be damaged from overheating,you need to clean the condenser coil where the fan is in the back of the fridge at least once a year but change the board out most of the time this is what it is
Sep 23, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Unable to reinstall
If you try to install another manufacturer's disk on another manufacturer's machine, it will not work.
For example, suppose you have a Dell motherboard go bad, you cannot replace the motherboard with an Asus board. The license will only work for a dell board.
May 27, 2010 | 321studios 321 Studios DVD X Copy (Backup,...
Bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Jul 27, 2009 | Bernina Virtuosa 160
Fresh-air purifier does not geenerate ozone
The fan is bad it should blow the fuse, I believe that the mother board has a problem, or the Display board may have gone bad.
Nov 04, 2007 | Ecoquest Fresh Air Air Purifier
KENMORE FRONT LOAD MODEL # 4174052500
It could be the computer board but in most of the cases the reason for your problem are: - A deffective lid switch - A blocked water-inlet line
Aug 22, 2007 | Kenmore 44042 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
367 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
